Warm up Time?
Old Nov 26, 2005 | 12:50 AM
fish4life's Avatar
fish4life
Warm up Time?
As a new diesel owner I was wondering how much time you should give your 7.3L IDI to warm up when starting cold?
Old Nov 26, 2005 | 05:09 AM
tjc transport's Avatar
tjc transport
i ain't rite
i start mine up, and slowly drive away so i don't wake the neighbors up. by the time i hit the highway, about 1/4 mile, it is warm enough to go.
Old Dec 11, 2005 | 01:10 AM
shrek13's Avatar
shrek13
i let my 92 7.3 idi warm up for 5-15 mins depending on how cold it is outside and if it was plugged in.
Old Dec 11, 2005 | 05:43 AM
shorthair's Avatar
shorthair
i start easing down the road as soon as i have full oil pressure.
Old Dec 11, 2005 | 07:13 AM
Saigon's Avatar
Saigon
I start down the road immediately with my 6.9 but rather slowly until its at temperature,no use in letting it idle for 15 minutes as the only thing you will heat up is the engine,remember that the tranny has to heat up too especially in the winter,that's done while driving!
Saigon
Old Dec 11, 2005 | 05:34 PM
_Gadget's Avatar
_Gadget
I start driving right away, but take it easy until the coolant temperature gauge starts to move.
Old Dec 11, 2005 | 09:04 PM
rancherman84's Avatar
rancherman84
i always wait for the CIA to kick off,then start rolling.
Old Dec 12, 2005 | 10:46 AM
diesel-weasel's Avatar
diesel-weasel
got to have heat coming out of the defroster or i can not see how to drive this time of the year18 to 20 degrees f
Old Dec 12, 2005 | 10:48 AM
njf207's Avatar
njf207
I let my 6.0 run for about 7 mins at first start up and that with it plugged in all night
Old Dec 12, 2005 | 11:53 AM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
If it is cold outside with my 93 - 7.3 I let it sit and run for a couple of minutes then start out slowly (not over 40) until the temp gauge starts to move. The colder it is the longer I wait to start out. Oil gets pretty thick and needs to thin out - to lube everything properly.
Old Dec 12, 2005 | 09:02 PM
92f25073idi's Avatar
92f25073idi
I also just wait for my CIA to kick off and let it idle down before I drive my 92 7.3
Old Dec 13, 2005 | 12:20 AM
smiller4597's Avatar
smiller4597
Wait for CIA to kick off then roll slow til she wants to go. She will let you know and so will the tranny.
Old Dec 13, 2005 | 05:35 AM
mwk's Avatar
mwk
It is usually real cold here, this morning it is 9 F. I can't use a block heater on the 83 so I just wait for the fast idle circuit to drop down and then drive very lightfooted until it hits operating temp.
Old Dec 15, 2005 | 07:37 AM
jeffdoerr's Avatar
jeffdoerr
i usually have mine plugged in overnight. I always start it and let it idle while I am doing chores. After all the animals are taken care of, then I head out for work. It probly idles for 5 to 15 minutes, depending on what all I have to do that morning before I leave. Sometimes I just get in a go (middle of the day), but it always runs at least 30 seconds and I always lightfoot for the first few miles.
Old Dec 15, 2005 | 02:58 PM
da1ton's Avatar
da1ton
what does your 7.3 idol at?
