battery dead again 5th time this year
Old Feb 11, 2002 | 12:45 PM
bigblue's Avatar
bigblue
Basic electronic troubleshooting skills are to cut the problem in half immediately. Do you have a charging problem, or short???
Measure the battery with the engine off. It should be about 12.5vdc. Then start up the engine. Measuring the battery now with the engine running it should be 14.5vdc, because that means the alternator is charging. If not, then a charging problem.
Pull your neg battery cable. Put an ammeter(multimeter on amps) between the battery post and cable. With the key off and doors closed, there should be NO current draw. If there is, then a short.
Old Feb 12, 2002 | 07:00 PM
7220driver's Avatar
7220driver
solved my dead battery problem when i replaced the ignition switch. It was'nt turning everything off.
Old Feb 12, 2002 | 07:41 PM
Mil1ion's Avatar
Mil1ion
[updated:LAST EDITED ON 12-Feb-02 AT 08:55 PM (EST)]Heads up to recent viewers.
Right from the start of his problems:
ALL the wiring/Power draining/troubleshooting
procedures have been suggested and done.
Maybe check the earlier replies.
Especially from his first thread.
https://www.ford-trucks.com/dcforum/electrical/513.html
Dennis
Please Don't Ask Me Any Tough Questions As:
"I'm Saving My Memory For When I Develop Alzheimer's"
78 F-150 429CJ,Silver
w/Explorer Pkge.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V
84 Volvo DL Wagon
Old Feb 12, 2002 | 08:06 PM
fordmaniac21's Avatar
fordmaniac21
as ,mil1on stated all the trouble shooting has been done. i have yet to try another new voltage regulater and this weekend when i get some time off i think im gonna test my ignition switch. that is the only thing i havent tested yet. illl let yall know what i find out if anything. thanks for the help and keep posting your findings.
'75 F-100 4x4, 4" lift
16x38.5x15 super swamper TSL
mini-spooled 9" rear end
390 w/ cam,headers,
and 4 barrell edelbrock
TRIED TRUE and FORD BLUE
Old Feb 12, 2002 | 09:39 PM
birdog79F150's Avatar
birdog79F150
just for the record had a 79 with the same simptoms after 2 alt starter volt reg ign switch two batts found the plug to the volt reg was vibrating loose and causing a drain on the system spread the terminals cleaned them and put on some dielectric grease and two years later still running strong though u might like to know
Six strings and Ford trucks music to my ears.:-staun
Old Feb 13, 2002 | 01:37 AM
karljay's Avatar
karljay
I just read about the use of dielectric grease and found that it's not a conductor but an insulator. It said to use WD40 on the actual connection and dielectric grease to help seal from water.
I don't know if its true or not, but if it is then dielectric grease would not be something you'd want to put on the connection points.
Old Feb 13, 2002 | 11:35 AM
birdog79F150
sorry about the confusion ,dielectric grease is to provide a moisture preventitive and stop corosion which was starting in my case ,i put it on all my electrical connections keeps them moisture free and good as new. just my two pennys.
Six strings and Ford trucks music to my ears.:-X11
Old Feb 13, 2002 | 01:30 PM
gilatrader's Avatar
gilatrader
I just bought a new set of spark plugs & a new wireset from AutoZone. The sockets of the wireset are pre-treated with dielecric grease. They also sell dielectric grease packets which instruct you to coat the spark plug insulator & tip with the grease. So much for dielectric grease being a insulator!!!
Old Feb 15, 2002 | 04:21 PM
Mil1ion's Avatar
Mil1ion
Old Feb 16, 2002 | 05:36 PM
fordmaniac21
i tries the wd-40 thing on the connectors for my voltage regulater and still the same thing. i went to go pick up my new 76 that i got for 150 and wouldnt you know the battery dies on me AGAIN. hopefully i can get this figuered out this weekend.
390 w/ cam,headers,
Ken_C
27
Feb 23, 2022 12:11 PM
firstgrasshopper
Nov 15, 2012 08:44 PM
CountryFried
1997 - 2003 F150
Sep 19, 2009 11:39 AM
Deac1970
1978 - 1996 Big Bronco
Jan 11, 2006 07:45 AM
blueovalboy_69
Nov 10, 2005 11:58 AM
