1978 - 1996 Big Bronco
Battery Drain
Old Jan 9, 2006 | 07:06 PM
Deac1970's Avatar
Deac1970
Battery Drain
1986 XLT 5.0L EFI 132000 miles
I Recently had some starting trouble that pointed to a dead battery. After replacing the battery and starter, I noticed a ton of corrosion around the battery cables, and solonoid. So, change 'um I did, and after changing out I got some wierd reading with my meter. Thinking it may be an alternater issue I first disconnected the alternator harnesses.
The battery disconnected is reading approx. 12V.
With the battery connected both Pos and Neg, it read approx 6.5V and was
dropping.
One by one I eliminated the fusible links on the solonoid and found that the one causing the drain was the black/orange link that feeds down to the alternator. I was getting a drain even with the Alt. harness disconnected!!
Any ideas?????
-Deac1970
Old Jan 10, 2006 | 06:15 PM
Deac1970's Avatar
Deac1970
Exclamation New Findings but Still stumped
after changing out a couple of fusible links and a broken alternator wire, the battery was still being drained so I started pulling fuses. When I pulled the courtesy light fuse, the battery drain stopped.
Does anyone have any ideas??
-deac1970
Old Jan 10, 2006 | 06:34 PM
BroncoRoadKill's Avatar
BroncoRoadKill
Well if you have it contained to that fuse start pulling bulbs untill the drain is gone, or it could be a bad socket or wiring.
Old Jan 10, 2006 | 06:49 PM
Black Ford XLT's Avatar
Black Ford XLT
Also consider this, what else is on that fuse, I own a 185 f-150 and had the same problem. It turned out to be the electric choke. The relay under the dash went south ( contacts closed) Draining my battery .I dont know whatelse is on your courtesty circuit, but also gives direction for another possiblilty. Good luck TR
Old Jan 11, 2006 | 07:45 AM
Deac1970's Avatar
Deac1970
Thanks for the insight guys, I just got the schematic and will now break out the meter, and open up a brand new bag of patience.
hydro man 17
Mar 21, 2013 11:45 AM
GoneFishen
Jun 14, 2010 08:14 PM
blakeusa
Electrical Systems/Wiring
May 4, 2008 09:14 AM
