more e40d problems
Old Nov 25, 2005 | 05:14 PM
deanj's Avatar
deanj
more e40d problems
The saga goes on, had the sealership read the codes (23) and (62). 23 was the FIRL sensor, replaced and could not clear code 62 with the code reader. Disconnected batteries and the code cleared. Drove for 20 miles and things were back the way they should be, then o/d started flashing and shifts were hard (the trans shifts thru all gears and the torque converter locks up) Code 62 is the torque converter clutches (i think) How can you determin if it really is the torque converter or is there another thing to do?
Old Nov 25, 2005 | 09:47 PM
PLC7.3's Avatar
PLC7.3
62 can also be generated by other non electronic related transmission hardware system.
Check all the trans electrical connections especially the one on the right side with the tin cover, remove the tin heat shield, remove the solenoid connector by pushing on the center tab and pulling up on the wire harness. To install push down until a click is heard. Always reinstall the tin heat shield.
When you replaced the FIPL did you set the voltages correctly........
Old Nov 26, 2005 | 06:38 AM
deanj's Avatar
deanj
Yes the FIPL was set according to factory. All the sensors (except the one on the side of the trans) are new, FIPL, Tack and the VSS. Will try the connector but I think I did that this time before replacing the FIPL
Old Nov 26, 2005 | 09:04 AM
PLC7.3's Avatar
PLC7.3
Might want to try this too........
Automatic Transmission Shift Rod or Shift Cable Adjustment... C6 and E4OD
1 Raise vehicle on jack stands or hoist. (I'd block well and scramble under)
2 From inside the vehicle, place the select lever in D/C6 and OD/E4OD . Hang a three
pound weight on the selector lever ( six pack still full)
3 Remove shift cable from the transmission lever ball stud/shift rod.
4 Pull down the lock tab on the shift cable body.
5 Position transmission lever in drive position. This is three detents from the front-most
lever position with the first position counting as one.
6 Connect the cable and end fitting to the transmission lever ball stud/shift rod.
7 Push up on the lock tab to lock the cable in the correctly adjusted position or tighten nut
and bolt.
8 Remove jack stands and lower vehicle from hoist. Remove three pound weight from
column shift select lever.
9 After making adjustment, check for Park engagment. Check the transmission control lever
in all detent positions with the engine running to make sure correct detent/transmission
actions, readjust if necessary. Reset the PRNDL indicator as required.
CAUTION:
Under no circumstances will it be permissible to adjust the cable/shift rod in any position
other than D for C6 or OD for E4OD.
Now all should be ok if it is in PARK and everything works, remove blocks.
Road test...................(drink warm beer)
Old Nov 26, 2005 | 11:03 PM
mhannink's Avatar
mhannink
hey since we are talking e40d does anyone know how to wire a mystery lock up switch on these things and if so please tell how
finitetime
Sep 6, 2014 12:20 PM
93f2507.3
Dec 20, 2013 05:24 PM
trackenator
Feb 2, 2010 01:36 PM
scout49601
Jan 6, 2005 01:23 PM
tigerhawk_212
1978 - 1996 Big Bronco
May 9, 2004 12:49 PM
