Engine loping and rough idle
Old Dec 3, 2005 | 09:40 PM
BadFord99's Avatar
BadFord99
Originally Posted by SilverBullet131313
What is IPR? And i am starting to have similar issues i think...idle is rougher.....not real smooth as before.seems to be constantly moving a little but never moved at idle before..and can hear it surge each time a little...and seems to be constantly down on power throughput operating temp and range.....almost like its not hitting on all 8....but obviously not that extreme but i hope you get what i am saying. And very rough on start ups. Sound similar?
The IPR is the injector pressure regulator; it is located on the aft side of the high pressure oil pump in the valley of the engine. Your symptoms seem to be similar to the ones I was having. I didn't have rough starts, but did seem to lack a bit of power, and it did start surging.
Here is the link to the IPR servicing proceedure.
http://cw-diesel.com/LuxSite/IPRInfo.htm
If this doesn't help, I would get a cylinder contribution test done to see if you have any weak or failing injectors. Hope this helps you a bit.
Old Dec 3, 2005 | 09:53 PM
SilverBullet131313's Avatar
SilverBullet131313
Where or who can do a cylinder contribution test??? And how much does that normally cost?
Old Dec 3, 2005 | 09:57 PM
BadFord99's Avatar
BadFord99
You can get it done at your local Ford dealer, or other local diesel shop with the capability; not sure of the cost, I didn't end up needing to get it done.
Old Dec 3, 2005 | 10:05 PM
SilverBullet131313
Ok great!!!
You siad you replaced the ICP and CPS......where is best place and approx price to get them from?
Thanks
Old Dec 3, 2005 | 10:40 PM
BadFord99's Avatar
BadFord99
Ok great!!!
Thanks
Ebay would be the cheapest if you are willing to wait a few days for shipping.
ICP approx 39.00, CPS approx 49.00-59.00
Old Jan 10, 2006 | 01:55 PM
clintbonnie's Avatar
clintbonnie
I have had the rough idle/loping on my 99 since it was new.. Being that this is my 1st diesel, i figured this is just normal when cold. After about a minute of warming up, it was ok.. (even parked in the warm garage over night it would lope). I was using Delo 400 for the last 64,000 miles. Well, to make a long story short, i switched last week to Shell Synethic 5w-40 and the "loging" competely disappeared even letting the truck set outside over night now. Injectors must really like the stuff.. I am impressed !
genius117
30
Jun 24, 2016 11:13 PM
foul1
Oct 30, 2009 07:00 PM
ztodd377
Nov 3, 2008 05:32 PM
Rand
1983 - 2012 Ranger & B-Series
Aug 15, 2008 08:27 PM
powderkeg
Oct 22, 2005 08:20 AM
