Need Help, Started Changing Gp
Old Nov 25, 2005 | 02:25 PM
SpoolingF-350's Avatar
SpoolingF-350
Well I got everything to do it, and started on the drivers side, took the vaule cover off and unplugged the block, then took the block off and thats were I am at now, there is a metal peice that seats above the gp. Does it maybe screw off, or pop off. I dont want to mess it up. Please help
Thanks Derek
Old Nov 25, 2005 | 02:58 PM
RushN350's Avatar
RushN350
I'm not sure what your refering to... If the GP is un-plugged it should screw out like a spark plug. Unless i'm missing somthing.
Old Nov 25, 2005 | 03:03 PM
SpoolingF-350
There is a block thing on top and it has three metal stripes on it that meshes with this other metal peice with three stripes that seats over the glow plug, it is like a inch by a inch big and it can turn but it doesn't seem like it is coming off or getting tighter.
Old Nov 25, 2005 | 03:04 PM
SpoolingF-350
It has two little holes in it if that helps
Old Nov 25, 2005 | 03:17 PM
BadFord99's Avatar
BadFord99
The only thing you should have to do is pull the glow plug connector and use a 10mm deep well socket to remove the glow plugs.
Old Nov 25, 2005 | 03:30 PM
SpoolingF-350
Sorry I'm a retard, I unplugged the the block thing and took that off and tought the glow plug was under that, I just notice the other wire that went to the glow plug, yea I dont understand the diesel thing yet give me a little bit.
Thanks guys sorry for being dumb.
Old Nov 25, 2005 | 03:35 PM
RushN350's Avatar
RushN350
Thats good at least you got it, you had me goin' I even got the book out and was still confused.
brokeasajoke
Oct 12, 2013 08:30 PM
51fordf5
Jan 19, 2013 09:03 PM
JDWard
Jan 9, 2013 07:48 AM
pba369
Oct 27, 2011 10:33 AM
brownie83
Mar 1, 2010 10:51 AM
