wts flashes once
Old Oct 10, 2013 | 03:24 PM
brokeasajoke's Avatar
brokeasajoke
wts flashes once
Wts light had been staying on 8-10 sec. Changed one bad gp and checked all and read about 1ohm each. Found one wire broke off gp connector. Repaired. Now light flashes once and dont hear gp relay click. What have i done or missed. Truck took at least 3 cranking attempts cold before thats why i checked them. 88 f350 7.3 na. Checked continuity on all gp connectors and wires back to control. I assume if a gp is good its good. I got 8 but i dont see the need on changing them if it wont help any. Thanx
Old Oct 10, 2013 | 06:40 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
maybe you disturbed a weak ground?
there are steps here to test that will help you figure it out:
Glow Plugs 101 Tutorial
Old Oct 10, 2013 | 07:08 PM
brokeasajoke
Going to replace supply wires from fender to relay tomorrow. Clean gounds. Got two 8ga wires and copper terminals for supply. May replace solenoid too jus for peace of mind and go from there.
Old Oct 10, 2013 | 09:15 PM
Arps 6.9's Avatar
Arps 6.9
When I put my truck back together Saturday, the glowplugs did the same thing. It was a bad ground to the solenoid, the small eyelet wire.
Old Oct 11, 2013 | 07:41 AM
brokeasajoke
If i ground the white wire with key on rely trips and wont disengage until i turn the key off. If i take the white wire off rely works on and off as i touch ground. Hot side of relay gets hot enough to burn you if you touch the terminal with relay tripped for about 5sec.
Old Oct 11, 2013 | 12:28 PM
brokeasajoke
Here is sme more info. Replaced gp supply with 2 8ga wires soldered to the oe fuseable links i cut out of wires. Cleaned and sanded all terminals and ground. Wts still one flash. Wiggled all gp connectors and one made relay solenoid kick on. So had wife watch light. Came on about 8 sec then went off relay stayed engaged and gp wires at controller metal "z" began to smoke. No cycling. And burnt my hand. Tried again and after about 20 sec cut key off was afraid to wait any longer for cycling. So i got test light out and found 2 more gp not working. I think i tested them wrong yesterday with multimeter. Dont think this episode burnt them out. I believe been out all along. Keep in mind before all this wts light normal and intermittent clicking leaving key on.
Old Oct 12, 2013 | 10:08 AM
brokeasajoke
No educated guesses on this one?
Old Oct 12, 2013 | 02:24 PM
FORDF250HDXLT
why guess when you have step by step testing instructions in the link provided in post #2?
Old Oct 12, 2013 | 08:30 PM
brokeasajoke
Ok so how long is safe for gps to continue heating. I counted 20 sec in my head and wires going to gps started smoking.Do they normaly continue heating that long? Yes i read the diagnosis. Im thinking control. Jus looking for confirmation before i drop the money on a new control unit.
GreenTerracePSD
Aug 7, 2014 09:13 PM
jhand124
44
Nov 28, 2013 11:07 AM
ttexastim
Dec 1, 2010 09:42 PM
Dwight Cordes
Bronco II
22
Aug 9, 2006 08:32 AM
morton
Mar 29, 2004 09:08 PM
