Grill Cover For Winter?
Old 11-25-2005, 01:30 PM
86'f250's Avatar
86'f250
86'f250 is offline
I was wondering where i could get a grill cover for my 86 f250 instead of using a piece of cardboard for these colder days in minnesota.
Old 11-25-2005, 04:39 PM
Piffery1's Avatar
Piffery1
Piffery1 is offline
If the cooling system has the proper thermostat and antifreeze solution, why do you need to block the radiator? I thought blocking radiators went out with alcohol antifreeze. When I was in Northern Michigan all our vehicles had 120 VAC heaters either in the lower radiator hose (which I preferred) or mounted on the block in a "freeze plug" hole. We also had a heat pad under the battery. Of course, none is needed in NW Florida.
Keeghan98
17
08-29-2023 01:05 PM
GHeTTo JOe
11-30-2008 01:06 PM
75f-250
08-31-2007 11:13 AM
lrd56
Paint & Bodywork
08-13-2004 09:57 AM
rk5400
1999 to 2016 Super Duty
09-12-2003 12:47 PM
Quick Reply: Grill Cover For Winter?
