Sponsored by: Real Truck
Speed sensor
Old Nov 24, 2005 | 10:54 AM
97fordDriver's Avatar
97fordDriver
Speed sensor
I have a 97 f250 HD, i was driving in the snow the other day in 4x4 when my speedometer started going crazy, then my transmission started doing the same thing.
It would shift into first regardless of my actual speed and in the snow it locked up all 4 tires. I was told its the speed sensor, but i was wondering if it could be anything else?
Old Nov 24, 2005 | 11:01 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Nov 24, 2005 | 07:56 PM
Texascadillac42's Avatar
Texascadillac42
It COULD be something else, but Id venture a guess towards the speed sensor. Its a cheap fix, about 30 bucks from the dealer, and easy as pie to replace.
Old Nov 24, 2005 | 10:46 PM
krewat's Avatar
krewat
Speed sensor. They can get crudded up with metal dust from the gears, or so I've heard, and you might be able to clean it, but if you're going that far, get a new one anyway.
While you're down there, check the fluid in the diff. If it's got a magnet in the fill plug, clean off the metal
art k.
Groundpounder0331
Dec 22, 2008 02:21 PM
Fleetwd
Oct 31, 2006 06:10 PM
wtppower
Oct 3, 2004 02:47 PM
Bezalel
Aug 12, 2004 09:44 AM
chrisjrosenbohm
1997 - 2003 F150
Feb 22, 2003 10:00 AM
