Frame/Body points?
Old Feb 19, 2002 | 10:49 PM
Crazy_John69's Avatar
Crazy_John69
Frame/Body points?
ok quick q here
can i sawp the body of a 1977 f-250 2x4 onto a 1976 f250 4x4 without drilling? i was hopeing it would bolt right up
Old Feb 19, 2002 | 11:25 PM
TKONO's Avatar
TKONO
Frame/Body points?
It should all be the same unless the 4x4 is a highboy, but man what a pain. John
Old Feb 20, 2002 | 06:24 AM
jowilker's Avatar
jowilker
Frame/Body points?
John, The 4X4 frame is narrower. The cab and front clip should work just fine. You will have to adjust for the bed holes.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
Old Feb 20, 2002 | 06:23 PM
jowilker's Avatar
jowilker
Frame/Body points?
Old Feb 20, 2002 | 08:37 PM
monckywrench's Avatar
monckywrench
Frame/Body points?
Swap away! It beats doing bodywork.
I use Kroil penetrant on the hardware, and buy urethane mounts if the old ones are hosed. The easy way is to lift off the whole front clip, then tip the cab sideways onto something soft like an old tire. I remove the door on the side I tip the cab towards.If you have to weld any floor panels, tip the cab on its back to make it easy.
I've done an F250 and F350 this way (with F100 cabs). The leftover chassis make nice trailers too. Clip the frame with a Sawzall just behind the suspension.
Old Feb 20, 2002 | 09:40 PM
79f3504x4's Avatar
79f3504x4
Frame/Body points?
That Sawzall also makes quick work of cab mount bolts.Less smoke than a torch.
