I NEED TO KNOW..................
Old Feb 24, 2001 | 05:26 PM
bondo's Avatar
bondo
What an ELECTRONIC REGULATOR DOES.I have a 1981 Ford F250. I am having starting problems. All it does is clicks...I have replaced the starter ,selenoid,& the battery.Could this little box be my problem? (it's located right below the selenoid,on the passenger side engine wall).---------p.s. my heater blower ,wind shield wipers and radio all stop working when i turn the ignition key.But my head lights don't dim.) any advice would help.-----
Old Feb 24, 2001 | 06:18 PM
mt66ford's Avatar
mt66ford
Electronic regulator is for your alternator, I am afraid it does not have to do with starting your truck. Did you buy a good starter or a cheap one ? may need to have switch tested or check connections and cables for good condition.
Old Feb 25, 2001 | 03:22 AM
hotrodford_88's Avatar
hotrodford_88
Check and replace your battery & starter cables!
1988 F-150, SWB, 5.0 EFI (formerly 4.9 EFI), M5OD 5 speed, 3.08 gears, Summit shorty truck headers, Custom built Flowmaster exhaust system. Force 4 LP6000 lightbar, Federal signal PA-300 100 watt siren, Icom IC-V100 50 watt mobile radio.
1965 F-100 (just purchased 1/18/01), SWB, 390, C-6 auto. Dual exhaust, Not much else to do to it.
Can see both below.
[link:www.geocities.com/hotrodford_88/|Hotrodford_88's Webpage]
Old Feb 25, 2001 | 10:00 AM
FTE Ken's Avatar
FTE Ken
for_play
17
Jul 23, 2001 02:27 PM
William
13
May 4, 2001 04:15 PM
daywalker
Apr 27, 2001 06:53 AM
marc51
Apr 12, 2001 05:30 AM
hotrodford_88
Apr 5, 2001 05:30 AM
