adjusting points
Old Nov 22, 2005 | 10:24 PM
fordguy76's Avatar
fordguy76
adjusting points
how do you adjust points after an install?
thanks.
Old Nov 23, 2005 | 05:00 AM
subford's Avatar
subford
thanks.
With a Dwell Meter or a Scope and a screw driver, set them to 30 deg. for an 8 and 60 deg. for a 6.
Feeler gauge will get you in trouble, don't ask how I know. I have also used a test light when I did not have anything else, just put the point on the wire to the coil and move them until it flashes.
Also see:
http://www.partsplus.com/shared/Mark...gineTuneUp.pdf
Old Nov 23, 2005 | 05:08 PM
Franklin2's Avatar
Franklin2
That's one thing GM got right that Ford didn't. Gm has a little window in their dist caps so you can adjust the dwell while the engine's running. With Fords you have to keep stopping the engine and taking the cap off to adjust it.
Tuxedo Scorpion
6.7L Power Stroke Diesel
Jun 12, 2012 10:38 AM
Zcarbuilder
Jan 8, 2006 10:49 PM
Chris-jack
May 10, 2005 01:16 AM
Thumper4995
Sep 10, 2003 09:07 PM
GeneStoner
Apr 7, 2003 12:20 AM
