i have no idea what to call them. turn-signal trim sounds good to me. i'm sure the dealer can help you, just drive it up there and show them what you need. like pilot said, they can't be expensive. maybe you can try a bone yard.
Well, I found the parts. They're listed as grille moulding, IIRC. Each little "eyelid" is about $25. So it'd cost as much for those two pieces, if not more, than I'll pay for the grille.
The only reason I'm considering replacing either the grille or the moulding is that the chrome is faded in a couple places where the water runs down off the hood and over them. Now that it's 20 degrees, I may just put off the whole project until warmer weather.
RangerPilot, I appreciate the offer. If you find those pieces, and they're not faded too, it still might be more cost than it's worth. If you get them for $5 each, and shipping's another $5-10, then I'd pay you for that. I suspect that any in the junkyard will have the same fading problem as mine does tho.
