1978 - 1996 Big Bronco
Tranny swap?
Old Nov 22, 2005 | 07:47 PM
matt351's Avatar
matt351
Question Tranny swap?
Hello all, My first question to this forum is this. I have to replace the tranny in my bronco, it has a C6 now, I want a 4 speed. Is there a 4speed close enough in length to fit without cutting and welding and relocating the crossmember and having new driveshafts made? Thanks in advance. Matt
Old Nov 22, 2005 | 08:49 PM
gov2mod's Avatar
gov2mod
What year is your Bronco and what engine is in it? Are you talking about installing a four speed manual or automatic?
Old Nov 23, 2005 | 08:27 AM
tapnibot's Avatar
tapnibot
similiar question...what about a manual tranny in place of my e4od in my 90 bronco full size. i hate that damn tranny..i can't tell you how many times im waiting for it to shift goin up a hill.
Old Nov 23, 2005 | 01:29 PM
matt351's Avatar
matt351
Red face sorry(re: tranny swap)
sorry about that, it ia '90 with a 351W. and i want a 4 speed auto.
Old Nov 23, 2005 | 02:54 PM
masseysbronco's Avatar
masseysbronco
don't forget to take into account the fact that you'll need a different transfercase adapter.
I don't know about the fit, but the easiest will probably be an AOD tranny because the E4OD will require all of the wiring and electronics to be transfered with it to make it work.
Old Nov 24, 2005 | 07:58 AM
gov2mod's Avatar
gov2mod
Matt351, I have a 90 with 5.0 and AOD automatic but I'm changing the engine to a 351W. I've found that all I have to do to use my AOD transmission is to change the flexplate (flywheel) to one that is for a Crown Victoria that had the 351W/AOD. So you need basically the same thing. Get an AOD transmission from a Bronco or F150 4X4 with torque converter and the flexplate from the Crown. Your BW1356 transfer case will bolt right up to it.
Flip4ford
Kansas Chapter
43
Jul 26, 2018 06:43 AM
matts72ford
19
Sep 6, 2011 08:05 PM
obey_your_master
May 2, 2006 08:59 PM
msnieg
New Member Introductions
Feb 26, 2006 08:52 AM
Matt67
Feb 23, 2002 05:34 PM
