Replacement Gas tanks
Old Jan 23, 2002 | 07:42 AM
EquineGuy's Avatar
EquineGuy
I need replacement gas tanks for my 1979 f-250 4wd. The local sources do not have them anymore, and some after market place in SC/NC do not make them anymore.
Anyone have links where I can buy 2 new/good used ones? I need them or else I can't play.
Thanks!
Old Jan 23, 2002 | 07:53 AM
EquineGuy's Avatar
EquineGuy
Ohhh.. and the front talk securing straps too... eheh
Old Jan 23, 2002 | 08:51 AM
Ford79's Avatar
Ford79
Could you take a picture of the old tank and post it on here? I might have one for you.
Old Jan 23, 2002 | 09:26 AM
beartracks's Avatar
beartracks
if it's behind the axle I recommend the 38 gal replacement steel tank from J.C. Whitney. It's made by a Canadian company and worked well for me. The 38 gal. requires moving the spare tire.
Bear Tracks
Old Jan 23, 2002 | 09:52 AM
EquineGuy's Avatar
EquineGuy
I need both.... I am sure it will cost me, but it will be worth it.
Thanks for the tip!!
Old Jan 23, 2002 | 10:21 AM
jlasater's Avatar
jlasater
I'm curious about available aux fuel tanks as well. My F250 has two of them, but they were home made, and look nasty. They each have two bolts through the bed of the truck supporting them and I'd like to replace everything with a pair of factory saddle tanks, or a single frame mount tank.
Old Jan 23, 2002 | 11:06 AM
Fastcat's Avatar
Fastcat
Does the JC Whitney tank fit the narrow frame of a F250 highboys? 27"
Old Jan 23, 2002 | 01:08 PM
teamwizard's Avatar
teamwizard
[updated:LAST EDITED ON 23-Jan-02 AT 02:21 PM (EST)]hey EquineGuy, i have the a frame mount gas tank, from my 79 f250 that i will not be using. if your interested give me an email at TeamWizardL7(No Email Addresses In Posts!).
C-ya
Gabriel
1979 F250 400ci, 4:10 gears-HD Dana44 front/Dana 60 rear Detroit locker, 4in lift, 35" mudders, mud on rust on black!
1999 F150 4.2L v6, dropped 4" in front/5" in back, 18" KMC Hellion rims, billet grill,euro taillites, hard tonneau cover, Kicker sound system(will be competing in shows soon), metallic silver.
Old Jan 23, 2002 | 01:24 PM
EquineGuy's Avatar
EquineGuy
E-mail on the way.
I have to find out if mine has that emmisions fitting or not. I know it has 2 hoses to the tank. Fill hose and a 1/2" hose riding next to it. Just want to make sure I get the right tank.
I am becoming fond of that 38 gal tank... eh eh
Old Jan 23, 2002 | 03:39 PM
bondo man's Avatar
bondo man
hey there
i have both tanks still in a parts truck, its a 77 supercab, both inlets are on the drivers side
email jcouse1@***.net
Old Jan 23, 2002 | 04:41 PM
Ford79's Avatar
Ford79
FYI, the supercab tanks are different from the tanks used in regular cab trucks. I bought a new tank for my supercab only to find out it didn't fit. Supercab tanks are 19 gal. There are two tanks for regular cab trucks: A) 20.2 gal. w/emisions hole(vent pipe toward front of truck). B) 22.5 gal. w/o emissions (vent pipe toward rear of truck). This info comes from the LMC Truck catalog and my own personal expieriences(4 different parts stores). The rear tanks are the same, however.AFIK no one makes new tank straps for the side mount tank, only the rear tank. I spent 2.5 hours on my back removing mine . Got them off without wrecking them.
Old Jan 23, 2002 | 04:49 PM
tetraruby's Avatar
tetraruby
On my '79 there's metal pipe (vapor line) that runs along the passenger side frame rail, it's a about a foot and a half behind the cab - there should be a rubber line where a second fitting from the AUX tank would / could meet it - easiest way to determine if you need the vapor vent / rollover valve is to see if that above mentioned line runs to your carbon canister - if you have one.
Old Feb 23, 2002 | 06:28 AM
Green Beast's Avatar
Green Beast
>Bear Tracks
Hey Bear,
I was thinking about putting the larger tank in my 77 F350 Supercab but I need to carry the spare while I have a slide-in camper. What did you do with your spare? Any ideas from anyone else?
Thanks,
Jeff in VA
Old Feb 23, 2002 | 06:17 PM
6t6merc's Avatar
6t6merc
Old Feb 23, 2002 | 07:33 PM
Fastcat's Avatar
Fastcat
Check aerotanks.com they have a 38 gal tank that fits the narrow highboy frame and goes behind the rear axle. It's $410 complete.
Eallend7
Mar 5, 2013 08:20 PM
bren7176
Apr 26, 2011 04:26 PM
No_BS
Apr 27, 2009 08:43 PM
bchunter
Dec 19, 2004 12:48 PM
lastchance
15
May 13, 2002 08:55 AM
