radio question
Old Nov 21, 2005 | 07:13 PM
fiveltr's Avatar
fiveltr
radio question
if the stereo is mounted too close to a large speaker magnet will it cause problems for the stereo??? tom
Old Nov 21, 2005 | 07:25 PM
idealtrucks's Avatar
idealtrucks
i don't know much about radios and sound quality, but my speaker, i believe is stuck to the top of my radio. It works just fine, in my opinion. My radio is just one of the old am/fm stereos, though, and not a modern one.
Old Nov 21, 2005 | 07:45 PM
fiveltr's Avatar
fiveltr
thanks, i relocated my stereo in the dash and the sound from the speaker is scratchy now. the only thing different is the radio is about a 1/4 in. from the speaker. mine also is an old am/fm model.
Old Nov 22, 2005 | 08:08 PM
baitmaster's Avatar
baitmaster
not sure, but maybe your signal is being messed up from the antennae. Speakers like to be in an area where the air cant get to the front and back of it at the same time. No bass that way. i had bad reception too, even with a new radio, so I replaced the antenna, found my old one had water in the bottom of it and was corroded.
Old Nov 23, 2005 | 11:35 AM
fiveltr's Avatar
fiveltr
thanks for the help. just came in from the garage........solved the problem. my stereo has wiring for front and rear speakers.........of which i'd been using only the front. when i moved the speakers to the rear wires it's fine. maybe something wrong in unit.
Old Nov 23, 2005 | 02:50 PM
Bob Ayers's Avatar
Bob Ayers
The magnetic field from a speaker won't affect the radio, but it will mess the head up on a cassette tape player if it has one....
Old Nov 23, 2005 | 07:05 PM
baitmaster's Avatar
baitmaster
I know this is a dumb question, did you turn the balance **** to see if it was all the way one way or another? but if you're running just one set of speakers, it doesnt matter.
jssf24
2009 - 2014 F150
Aug 20, 2010 05:01 PM
Bsienki
Feb 24, 2004 01:32 PM
Diesel Steve
Electrical Systems/Wiring
Sep 4, 2002 08:54 PM
Drawsoncad420
Escape & Escape Hybrid
Mar 4, 2002 10:15 PM
tonka
Nov 4, 2000 08:10 PM
