Engine stops.
Old Nov 21, 2005 | 04:55 AM
kvalen's Avatar
kvalen
Engine stops.
Here is an problem from Norway.
My 2000 F-350 crew cab stops.
Under normal driving the engine just stops Then i can start it again after 15 min. and everything is ok. The engine can be idling for 45 min. and everything is ok . If i then take it for a drive it can stop. I have cheked the fuel filter and the fuel lines.
I think it must be an electrical problem in conection with the fuel. It doesent even give me an OBD report.( no codes stored)
Does annybody have an idea?
Old Nov 21, 2005 | 07:05 AM
mueckster's Avatar
mueckster
Sounds like the cam position sensor going bad. Does the tach move slightly when cranking the engine after it dies or does it start up right away?
Old Nov 21, 2005 | 07:30 AM
Kwikkordead's Avatar
Kwikkordead
Welcome to the Forum kvalen.
I agree with mueckster. The CPS is the most common failure with the symtoms that you describe.
Here's a link with a great picture of it's location.
https://www.ford-trucks.com/forums/s...d.php?t=431669
Old Nov 25, 2005 | 01:17 AM
kvalen's Avatar
kvalen
Thanks .
I changed the CPS and everything is back to normal.
Kvalen
Old Nov 25, 2005 | 01:35 PM
Wings's Avatar
Wings
Welcome Kvalen. Stick around, you can learn alot here at FTE. The experience and knowledge here is awsome. Holy Cow!! Are you from Norway? I have dear friends in Sweden. What a beautiful region.
Hey guys. I think FTE has gone global......
