1978 - 1996 Big Bronco
Should I drive with these Codes?
Old 11-20-2005, 10:25 PM
ctch88's Avatar
ctch88
ctch88 is offline
I did a quick run over the truck tonight b/c I have a 320 mile trip coming up. I pulled the following codes and was wondering if I should not drive that distance with the current codes.
KOEO:
26 TOT sensor out of test range
Continuous:
31 PFE or EVP circuit below minimum voltage of .24V
KOER:
21 ECT out of test range .3-3.7V
44 thermactor air injection system inoperative (right side)
33 EGR valve opening not detected
77 failed to read WOT (user error)... I did hit the throttle after the promt though, so don't know why this showed up
I am most worried about the EGR valve, it is a junkyard part, but this is the first time I've gotten the code. Any input is appreciated.
Thanks,
Kyle
Old 11-20-2005, 10:52 PM
chrono4's Avatar
chrono4
chrono4 is offline
well, with a junkyard part, its gonna be close to goin out, just like yours. just change that out.
Old 11-20-2005, 10:59 PM
tigerhawk_212's Avatar
tigerhawk_212
tigerhawk_212 is offline
You could clean your egr valve or replace the evp since its a very quick and easy replacment with a new unit if ure in a hurry unless you want to spend time testing the evp to make sure its bad. I believe the ECT could mess with your performance and drivability if its messed up. If you felt you needed to replace it you know its a fairly quick procedure but then you have to mess with a bit of coolant. I would check out the connections first for this stuff. Maybe disconnect the battery and reset the computer drive a bit then recheck the codes again right after that. Was your truck warmed up when you checked these codes?
Old 11-20-2005, 11:09 PM
ctch88's Avatar
ctch88
ctch88 is offline
I idled the truck for about 10 minutes, but it is cold here in Iowa, so the thermostat still hadn't opened. The reason I asked if I should drive on them is because even though I have access to a lot of tools, discluding a voltmeter though, I only have a parking lot to work in.
In short, I'd like to wait until I get home where I have a heated garage to work in with all the tools I need, unless I need to fix any problems before driving over 300 miles at highway speeds.
Old 11-20-2005, 11:39 PM
tigerhawk_212
I suppose you could drive the trip and make it but that would really be hurting gas mileage and performance. If I was you I would probably change out the evp since its so easy and just 3 screws and hope that solved my egr problems but thats under the conditions you have. It would be best to check the stuff first but since you say can't do it now.....that would seem reasonable, to me at least. Good luck with the trip though.
Old 11-20-2005, 11:53 PM
ctch88's Avatar
ctch88
ctch88 is offline
Thanks for the help, I'll change the evp and let you know how it goes.
Zorfox
07-24-2015 12:30 PM
d3ryl
05-03-2010 08:00 PM
narcolepticpug
03-21-2009 10:41 PM
bebad96
19
07-31-2004 05:53 PM
tstrickland
1983 - 2012 Ranger & B-Series
08-24-2001 09:35 PM
Quick Reply: Should I drive with these Codes?
