EVP Circut check!(EGR valve) Need help!
ok so i am trying to figure out whats wrong...
i disconnected the EVP electrical connector from the EGR valve
and tested the evp wire harness and the voltage was withing range(5.3v)
Then i went to check the EVP sensor itself. it ranges from 3400ohms to 510ohms(it should be 5000ohms-100ohms).
does this mean i have to change my evp sensor. or does it mean there is somthing wrong with my egr valve?
93 f250 4x4 460ci
93 f250 4x4 460ci
I would just replace the sensor and delete the EGR completely.
Ford Fuel Injection EGR Vacuum Regulator (EVR)
ceej4801
120
09-20-2016 07:51 PM
Doc TeeRay
12-01-2015 01:36 PM
Tim Hodgson
45
10-05-2015 10:25 AM
