engine change
Old Nov 20, 2005 | 08:59 PM
frenchman's Avatar
frenchman
engine change
hi everyone
I am preparing myself for the winter and i am still not sure what to do , i am putting a 429 in my 56 mercury m-100 and i am keeping the solid front axel but a droop one, i am planning to fabricate a crossmember for the engine mount but i am still not sure about the oil pan, does somebody know if i have to put a front or a rear oil pan.
THANK YOU
Old Nov 21, 2005 | 01:49 AM
rhw's Avatar
rhw
I have no idea but I just hated seeing your post set with no replies! Welcome aboard! I'm sure someone here has done this one and will have some pointers for you soon!
Old Nov 21, 2005 | 06:18 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Originally Posted by frenchman
hi everyone
THANK YOU
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Nov 21, 2005 | 06:45 AM
WillyB's Avatar
WillyB
I am sure you will need a rear sump - but I have never done it so you had better wait for aomeone who knows more than me. I will say that most of the posts about switching to a V8 indicate a rear sump is required.
Not many keep the original suspension/steering - but I like it and would myself. I expect you will want power steering for it, as well as a set of disk brakes.
Be a nice winter's project - and a near ride when you are done! What sort of tranny you going to run?
Old Nov 21, 2005 | 07:02 AM
frenchman's Avatar
frenchman
Hi ***** B
I got the mecanic out of a 1968 ford thunderbird, 429+ c6+ 9.5 rearaxel .
I already bought power steering and disk brake and found a automatic steering column.
COOL.
the engine is gone for the overhaul of 500+ HP
Old Nov 21, 2005 | 07:33 AM
AXracer's Avatar
AXracer
Most of the sump problems come with IFS conversions where the crossmember runs under the engine. With the stock suspension/straight axle there is no crossmenber under the engine so almost any pan should work.
500 HP in a pickup should spin the tires at idle!
Old Nov 21, 2005 | 08:41 AM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
When I put the 500ci Caddy in my 49 I opted to go for the rear sump pan as insurance. With the front sump pan it looked like if I bottomed the suspension the axle would hit the pan.
Set it all in place and see what it looks like, you might get lucky
Welcome to the board!!
Bobby
Old Nov 21, 2005 | 11:34 AM
Earl's Avatar
Earl
Welcome Frenchman. As you've already seen, there are a bunch of helpful folks on the forum who will do their best to answer your questions.
Old Nov 22, 2005 | 09:22 PM
dlister's Avatar
dlister
I put a 460 in my 58 and the front sump cleared the axle just fine.
