carbon buildup removal
Old Nov 19, 2005 | 11:45 PM
pageparsley's Avatar
pageparsley
i have installed a new 302 crate engine and have been playing a game of hit and miss with setting my timing and air fuel mixture. in the process of this is is possible to buildup carbon on the heads as a result of running the engine way to to rich. i have really blackened up a couple sets of new plugs in this process. this is the first time i have ever tried doing all this so i am usually always doing the old live and learn thing. i had it running pretty good a couple of times but when i do a little tweaking here and there it just throws things out of whack again. do i set the timing by taking plug out of number one cylinder and hold finger over it. then turn engine over a few times till air blows out number 1. then line up number 1 on cap with where rotor points at. i bought my distributor with a timing advance already set they said so i dont have to do anything else as far as that goes right. thanks for any help!
Old Nov 20, 2005 | 12:00 AM
baddad457's Avatar
baddad457
With a new engine, it'll take a LONG time running rich to build up enough carbon to affect anything. Run a few bottles of Chevron's Techron additive to remove what's there and periodically run their gas to maintain it.
Old Nov 20, 2005 | 05:04 PM
Franklin2's Avatar
Franklin2
That will get the dist in the ballpark if you took it out. If it will start, then set the timing with a timing light. Once you get a baseline set, you can then arbitrarily advance the timing a little bit, then go for a test drive and listen for pinging on hills. Keep doing this till you hear pinging, and then back off a little bit. This will be the best timing setting for the set-up you are running at that time.
AspenF150
General Automotive Discussion
Aug 1, 2016 01:19 AM
Vanzal15
22
Feb 10, 2016 05:13 PM
dadsutton1
2004 - 2008 F150
Oct 15, 2015 08:53 PM
Horace T
15
Jun 12, 2012 07:05 PM
j4henry
Mar 19, 2012 06:16 PM
