Sponsored by: Real Truck
outside air temp
Old Nov 19, 2005 | 09:53 AM
beemr's Avatar
beemr
outside air temp
My outside air temp display seems to be reading 4-6 degrees higher than actual temperature.
Is there a way to calibrate so it shows the correct temperature?
Old Nov 19, 2005 | 10:59 AM
mrc59's Avatar
mrc59
Yes. Subtract 5 degrees from the reading. I'm not being smart. You've already calibrated!
Old Nov 19, 2005 | 04:12 PM
beemr's Avatar
beemr
...so, there's no way to adjust the reading?
If it read 120 when it was actually 96, I would have to just do the math?
Old Nov 19, 2005 | 04:13 PM
beemr's Avatar
beemr
(darn, I hate being ****...but it drives me crazy not knowing if I have to live with it, or if it can be fixed)
Old Nov 19, 2005 | 05:27 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Try your dealership - it may be able to be calibrated with a WDS
Old Nov 20, 2005 | 05:55 AM
mrc59's Avatar
mrc59
Hey beemr, a couple degrees variance one way or another is normal tolerance. I have termometers around the house that are +2 or -4. 24 degrees off is a different story: that unit needs replacing! Let us know if it can be fixed, will you?
Old Nov 20, 2005 | 09:23 AM
beemr's Avatar
beemr
Thanks, MRC59, I guess I fall within the tolerance being it is about 4-6 degrees off.
The 24 degrees was just an example.
kingrl2
2009 - 2014 F150
16
Apr 24, 2021 10:31 PM
roadkingfl
6.7L Power Stroke Diesel
13
Feb 2, 2015 06:50 PM
doublenot7
Nov 17, 2011 10:25 AM
BlackstarF250
Apr 2, 2011 03:47 PM
ke6zmy
Jun 14, 2010 09:00 PM
