Sponsored by: Auxito
HELP!!!!!!!!!!!!! Shifter Needle Problem
Old Nov 18, 2005 | 12:41 PM
marshall99f150's Avatar
marshall99f150
I have a 99' F-150... I'm new to this forums just registered today... I just bought the truck it has about 190,000 miles on it and runs great and has no electrical problems. The tranny slips a little bit but im guessing that is from the mileage. It has a 5.4 with an auto tranny. I just installed an aftermarket strereo a pioneer headunit with two mtx 12's. sounds awesome.
I have a problem with the shift needle on the dash. It is way off. When i'm in park, it says reverse and when im in drive it says im in second. does anyone else have this problem? is there a fix and if so what can i do? Any help is greatly appreciated.
Old Nov 18, 2005 | 01:15 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Nov 21, 2005 | 08:04 AM
fbodyfan's Avatar
fbodyfan
If I remember right, it's a pretty simple fix. As long as it operates okay, it's not an immediate thing, but I know somebody will be able to help you with this.
Old Nov 23, 2005 | 12:25 PM
jrlowscot's Avatar
jrlowscot
I have messed with the one on my truck. if you look under the dash right under the steering column there should be a small cable. one end of the black plastic covering ends and mounts to the column and you can see the exposed wire as it goes up and towards passenger side. At that mount there is a small black wheel with teeth like a gear. By rotating the gear it adjusts the length of the cable, and after a few tries moving the gear selector you should get it right.
Hope this helps, I could email a picture if my description is too vague.
rchall2
21
Jul 3, 2023 04:44 PM
Toplait
Jun 8, 2012 08:36 PM
biscuit141
1997 - 2003 F150
Sep 22, 2009 12:19 PM
