Valve cover gaskets?
Old Nov 18, 2005 | 10:46 AM
dirttoo's Avatar
dirttoo
Are the valve cover gaskets re-useable on my '99 psd when changing my glowplugs? Why do they cost so much? Thanks
Old Nov 18, 2005 | 10:55 AM
qman's Avatar
qman
I don't know but get used to it. This is my first PSD and from what I've read, everything costs a lot. $250 for a water pump, $800 for front wheel bearings, etc. I think the water pump for my 94 Suburban was $40 and for my 92 F150 was $17.
Old Nov 18, 2005 | 10:59 AM
bhiggins's Avatar
bhiggins
they can't be that much and nothing is as agrivating as a leaky valve cover gasket coating your engine with oil
HeatStroked's Avatar
HeatStroked
I believe the injector wiring harness is incorpoated somehow into the gasket.
Old Nov 18, 2005 | 12:49 PM
tjbeggs's Avatar
tjbeggs
yes they are reuseable. not sure what the cost is but the cost of having a gutless gas engine is way more.
Old Nov 18, 2005 | 06:24 PM
stroker2's Avatar
stroker2
Heatstroked is right. The wiring is incorporated into the gasket, and makes it expensive. Here's a picture:
http://community.webshots.com/photo/...49314641rstBpF
It's my understanding they are reuseable, but the connectors have a bad habit of going bad.
Old Nov 18, 2005 | 07:02 PM
stroker2's Avatar
stroker2
I stand corrected. I went looking for a price and found the gaskets for about $38 - $40 on line. I think the gaskets go around the connectors or the connectors fit into the gasket. The picture I gave a link to was the gasket and harness combined. Sorry.
Old Nov 19, 2005 | 10:25 AM
tjbeggs's Avatar
tjbeggs
the gaskets have a 2 way plug molded into them. the outside harness plugs into it then the under valve cover harness plugs into the inside plug. when there is a melt down the plugins also get melted at times
