V10 engine dimensions
Old Nov 18, 2005 | 12:42 AM
freebee70435's Avatar
freebee70435
Question V10 engine dimensions
I am planning a swap. and I need the dimensions on the V10.bottom of pan to top, front to rear and sise to side of a complete engine. I have searched all over the net and cant find a thing. Even sent Ford a couple of emails(with no answer, thats gratitude for you) I dont want to do the standard 429/460 swap (I have 2 429s 1 a SCJ the other a PI). I want to do it different. HELP
Old Nov 18, 2005 | 01:44 AM
uuranium's Avatar
uuranium
the crank is 26.62 inches over all length. thats the only thing i can find so far. if it helps, i've been told that the engine is only 2.5 inches longer than a 302.
Old Nov 18, 2005 | 06:46 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Nov 18, 2005 | 12:27 PM
Mike G's Avatar
Mike G
First off, welcome aboard!
Secondly, I would recommend you stop by your favorite local Ford dealer and size it up yourself. If not, check with the crew at the V10 forum a little further down the forum list.
--Mike
Old Nov 18, 2005 | 07:01 PM
uuranium's Avatar
uuranium
i was thinking, wouldn't it be the same size as a 5.4l hieght and width? they are after all the same motor(relatively) but with the 5.4l missing 2 cylinders.
Old Jan 1, 2006 | 11:50 PM
freebee70435
Come on guys. I tried to do it on one that is in the truck, the new trucks arent like the antiqes, popped the hood and its pretty much fender to fender. somebody out there has pulled one of these out to do some kind of work on it, give me a hand fellas and use a tape measure on it please. then post it. I know it would help a lot of people.
thanks RB
Old Jan 2, 2006 | 02:25 PM
frederic's Avatar
frederic
Measure from underneath. Plenty of room to slap in a tape measure.
429thunderjet93f350
Mar 26, 2015 10:46 AM
tinman52
Jan 30, 2012 12:25 AM
1972 Ford Thunderbird 429 V8
Dec 19, 2008 05:42 PM
dino
21
Dec 18, 2005 10:30 PM
13
Apr 13, 2003 09:07 PM
