Fuel leak
Old Nov 17, 2005 | 10:36 PM
troubledsol's Avatar
troubledsol
Fuel leak
Help on this would be great my 2000 F250 is leaking diesel fuel from the fuel filter assembly this was just noticed since it got realy cold in cincy it is coming out of the drain valve hose onto the ground though valve is closed fully it still continues to drip any ideas
Thanks
Old Nov 17, 2005 | 11:08 PM
mech2161's Avatar
mech2161
Call Black Cloud they have a rebuild kit. http://www.blackclouddiesel.com/Ford/codepigtails.htm
Old Nov 18, 2005 | 08:45 AM
troubledsol
Thanks alot mech2161
Old Nov 18, 2005 | 08:51 AM
MrGrnJns's Avatar
MrGrnJns
Just last week, I had a similar problem. I had fuel leaking from the drain tube also, mine started after replacing the fuel filter though. My problem was corrected by working the drain valve open and closed a couple of times.
Old Nov 18, 2005 | 05:06 PM
empiretc's Avatar
empiretc
Question
I just noticed that my truck has a leak as well. It is leaking from around the release valve. Do you think this kit from blackcloud would correct this as well? Do you have to pull the entire fuel bowl out to do this?
Old Nov 18, 2005 | 05:17 PM
troubledsol
I fixed mine till the black could o rings get here by flipping the stock o rings over drip is no gone competely gone though greatly reduced
When removed you could see 2 indentations in the o rings caused b the valves molding my guess is now that it is colder the rubber has stiffened and isnt sealing as well as normal
Old Nov 18, 2005 | 05:48 PM
empiretc's Avatar
empiretc
Was your leak around the valve as well troubledsol? Mine leak diesel from around the valve and it sits on top of the engine. It is not too bad, and I never saw diesel in the carport. Only reason I saw it is cuz the guys from the tranny shop spotted it and told me about it.
Old Nov 19, 2005 | 01:55 AM
empiretc's Avatar
empiretc
Does anyone think it is the O-rings? For $6 I am gonna try them.
Old Nov 19, 2005 | 09:51 AM
Kwikkordead's Avatar
Kwikkordead
I've never done that job to know for sure, but I would be surprised if that doesn't fix it.
Old Nov 19, 2005 | 10:11 AM
troubledsol
Mine only leaked to the ground through the drain tube though it very well could be those o rings worth a try
Old Nov 19, 2005 | 10:13 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
The o-rings are by far the most common leakers. $6 is easily worth it to find out. The filter bowl does not need to be removed to get the seperator valve off, but it is a little tight in there.
Old Nov 19, 2005 | 11:24 PM
empiretc's Avatar
empiretc
Thanks Cookie and kwik. I have been eyebolling this for this past couple of days and it is definitely around the release valve. I already ordered that kit from bcd because I was told these orings are specific. I have boxes of them, but I dont want to risk it. I am suprised that the valve doesnt have a gasket of any type. I think when I put the rings in I will line the valve with permatex to help seal better. Do you think that would be a good idea?
Old Nov 20, 2005 | 12:32 AM
Kwikkordead
An o-ring properly set in it's little groove makes a better seal than a gasket because it follows the expansion and contraction better IMO. Avoid Permatex and equivelents like the plague. It will glue the o-rings in place and immobilize them from doing what they do best is seal things up even when things are expanding and contracting with the thermal cycles of the engine. Use a VERY light coating of silicone grease on the o-rings so that they can seat properly = no leaks.
Old Nov 20, 2005 | 12:40 AM
empiretc's Avatar
empiretc
Sorry, i wasnt talking about putting permatex on the rings, but rather between the valve and the fuel bowl. From pictures I have seen there is nothing in between.
Old Nov 20, 2005 | 12:46 AM
Kwikkordead
Is there an o- ring that seals the valve body to the fuel filter housing?
