Fuel leak
Old Nov 20, 2005 | 12:53 AM
empiretc's Avatar
empiretc
As far as I know, there are only 2 in/out.
What I mean is like when I replaced the a/c blower on my old truck I put permatex on it when I replaced it. This sealed between the screws and everywhere that there could have been a leak. I was thinking of doing this around the valve every where else (not the orings).
Old Nov 21, 2005 | 03:46 PM
empiretc's Avatar
empiretc
I was told the following:
Note the two orings with what apears to be paint on them. They are 1/2"OD X 1/4"ID and cost about .50 cents each at a plumbing supply store.
I ordered the kit from BCD. I was thinking that they would be metric orings. Does any one know if this is the size they are? Should I just wait for the kit to come in. The leak is getting worse...
Old Nov 21, 2005 | 11:54 PM
SpringerPop's Avatar
SpringerPop
O-rings are 1/2" OD, 1/4" ID, 1/8" material.
Danco #90 at Home Depot.
There are two of them.
Pop
Old Nov 22, 2005 | 12:10 AM
empiretc's Avatar
empiretc
Thanks so much SpringerPop. I'll have to run down to the home depot and get some then. I might have to wait a while to get that order from BCD considering the holidays are upon us. I was also told of a ratchet made by stanely that also works by twisting the handle makes it really easy to get those 4 #20 torx out of there. I'll check it out.
Old Nov 26, 2005 | 06:15 PM
empiretc's Avatar
empiretc
The kit from BCD came in today. Took me 45 minutes to get them in. Now there is no leak!! The orings are metric and are thicker than the Danco#90. No one had them locally (no #90 either), so I advise everyone who needs them- just get them from BCD! 100% perfect!!!
Old Nov 26, 2005 | 06:31 PM
SpringerPop
I won't attempt to defend my use of the clearly incorrect o-rings, but I can tell you this:
After almost a year of having them installed, I still have no leak. I had a leak with the old, factory, yellow ones.
When I get my next leak, of course I'll buy the correct ones to replace mine.
In the meantime.......
Pop
Old Nov 27, 2005 | 12:45 AM
empiretc's Avatar
empiretc
Hey, no offense Pop- I went looking for the Danco #90s and if they would have had them anywhere, I would have bought them and put them in. Getting the leak stopped was my main priority. However, since I couldn't get them anywhere I had to wait for the ones I ordered. Once I got them, I miked the old ones and new ones just to know for sure cuz I figured since everything on the truck was metric, the orings had to be too.
Old Nov 27, 2005 | 01:18 AM
SpringerPop
I wasn't offended, no worries. I will be putting the yellow ones in when it comes to it.
I would be interested in the measurements, however, as the SAE size was sooooooo close.
What size are they in metric units?
Pop
Old Nov 28, 2005 | 10:18 AM
RShaips's Avatar
RShaips
I am new to diesels and have some questions. My 2000 Excursion just started to leak out of the tube that you guys are talking about. I replaced the fuel filter about a month ago, Truck has 116,000 miles on it. I see the kit you are talking about,can't I buy this at the Ford dealer or auto parts store? what is its purpose anyway? Thanks for the help.
Old Nov 28, 2005 | 01:55 PM
empiretc's Avatar
empiretc
The valve is used to drain the fuel when when you replace the filter. No auto part store carries the right orings, and the dealer will only sell you the entire assembly (around $300). You can try and hunt down the Danco #90 orings that Pop suggested. I would have but couldnt find them anywhere.
Old Nov 28, 2005 | 06:21 PM
SpringerPop
If you have not got the time to get the yellow ones, and you have a Home Depot close, look in their individually-packaged o-ring drawer section for a UPC number 037155-358700. That's a Danco #90. 1/2" x 1/4" x 1/8".
Ask at their Pro Desk how many their computer system shows should be in stock, and ask for help finding them.
Wish I had the Home Depot SKU number for you, but they can look it up with the UPC.
Print this out and take it with you.
Then, you're going to need a torx driver to remove the screws that hold the valve together.
Pop
Old Nov 28, 2005 | 07:21 PM
Black88GT's Avatar
Black88GT
I have to jump in here, I have a 99 7.3, and Ive noticed the smell of unburnt diesel for a while, but never gave it too much thought. recently I notice a little smoke from in the front of the truck in the morining as Im sitting at a stoplights. So I have determined I might have a fuel leak Where should I check first? Are there common places that would tend to leak more? Thanks, Im off to search
Old Nov 30, 2005 | 08:13 AM
  #28
Big_worm's Avatar
Big_worm
All of these posts are good. I have a fuel leak and it is pretty bad. I am spending too much on fuel weekly, and sometimes, I have to refuel each day.
Old Nov 30, 2005 | 08:19 AM
  #29
RShaips's Avatar
RShaips
I just ordered the kit that you guys recomended. Looks easy enough to fix. Thanks for the help
Old Nov 30, 2005 | 11:28 PM
  #30
Kwikkordead's Avatar
Kwikkordead
Nothing like flushing $$$ down the drain.
90pioneer
Jun 16, 2013 01:55 AM
'94IDITurbo7.3
25
Mar 16, 2012 12:36 PM
henslee
Aug 26, 2011 12:47 AM
cl361
New Member Introductions
Jan 14, 2007 08:45 PM
ekmath00
Jan 31, 2005 12:59 AM
