diesel fuel and rtv
There is a special type of pipe sealant specifically made for use in fuel applications, gas, natural, diesel, etc.
If your fitting and threads are in good shape, this stuff will do the trick. I think its called Harvey Seal.
I used it on all of the fittings on my aux fuel tank and pump and haven't had a leak in 8 years so far.
Jason
Jason
Jason
Jason
from what i've read, those are supposed to have an "olive" to seal them, basically an o-ring made of rectangular stock. sealant may get by for awhile, but its best to figure out what the factory intended and go with that.
as for RTV, i was under the impression that it was dissolved by the alcohol in gasoline, and since i've never found non-alcohol gas, i've always avoided it with gas. never thought to try it with diesel
Ok just making sure, if the regular way of sealing/or assembling doesn't work I usually find its because I'mgoing it the wrong way.
