It a Kenmore, and its 7 year old, 220 volt electric dryer. It takes about 2 hours to dry a load of cloths. It has a heater element, thermal fuse, thermostat 250 degrees. Dryer heats to 210 inside the empty drum, only while the heating element is on. The cycle is it heats for 20 seconds ( heating element turns red ) then the element cools off, then heats up ( turns red again ) after 3 minutes. The dryer vent and screen is clean of lint. I think it use to take about 50 Min's. to dry a full load of cloths, when the dryer was new. I see the thermostat should go to 250 F, maybe its a bad thermostat? What does the thermal fuse do?
Thanks guys for any help,
Mike
My wife had the same problem... What I found was the vent tube was clogged about half way to the outside vent. It didn't have any air flow. I found it when I re-located the vent system. Try disconnecting the drier and run a sewer snake or a large brush down the tube....jusy my $.02
oures is doing the same but it still take the same time to drie the clothes but they come out wet and on other days it dryes them compeatly i think is the element but the drier is almost 50yrs old so we will just replace the whole dryer
I found out you can bi pass each and or all buy taping each thermostat two wires together. If it heats long then chances are the thermostat is bad. Both thermostat to the heater element were bad and now it works!
