2000 ranger question
Matt
CONDITIONS DETAILS/RESULTS/ACTIONS
A1 TEST THE BRAKE LIGHTS
Apply the brake pedal and view the brake lights.
Do the brake lights illuminate?
Yes
GO to A7 .
No
GO to A2 .
A2 TEST FUSE 16 (15A)
Fuse 16 (15A)
Is the resistance of Fuse 16 ohms or less?
Yes
GO to A4 .
No
GO to A3 .
A3 TEST CIRCUIT 10 (LG/R) FOR A SHORT TO GROUND
Brake ON/OFF Switch C210
Measure the resistance of Circuit 10 (LG/R) at C210.
Is the resistance 10K ohms or less?
Yes
REPAIR Circuit 10 (LG/R) for a short to ground. TEST the system for normal operation.
No
GO to A4 .
A4 TEST CIRCUIT 10 (LG/R) FOR AN OPEN
Measure the resistance between the output side of Fuse 13 (15A) and the brake ON/OFF switch Connector C210, Circuit 10 (LG/R).
Is resistance 5 ohms or less?
Yes
GO to A5 .
No
REPAIR Circuit 10 (LG/R) for an open. TEST the system for normal operation.
A5 TEST THE BRAKE PEDAL POSITION SWITCH
Measure the resistance of the brake pedal position switch while open (OFF) and closed (ON).
Is the resistance of the switch greater than 10K ohms while OFF and 5 ohms or less while ON?
Yes
GO to A6 .
No
REPLACE the brake pedal position switch. TEST the system for normal operation.
A6 TEST CIRCUIT 511 (LG) FOR A SHORT TO GROUND
Shift Lock Actuator C212
Measure the resistance of Circuit 511 (LG), Pin C212-1.
Yes
REPAIR Circuit 511 (LG) for a short to ground. TEST the system for normal operation.
No
GO to A7 .
A7 TEST CIRCUIT 511 (LG) FOR AN OPEN
Measure the resistance of Circuit 511 (LG) between the shift lock actuator Connector C212-1 and the brake ON/OFF switch Connector C210.
Is the resistance 5 ohms or less?
Yes
GO to A8 .
No
REPAIR Circuit 511 (LG) for an open. TEST the system for normal operation.
A8 TEST FOR B+ ON CIRCUIT 1003 (GY/Y)
Measure the voltage at the shift lock actuator Pin C212-3, Circuit 1003 (GY/Y).
Is B+ present?
Yes
GO to A12 .
No
GO to A9 .
A9 TEST FUSE 10 (7.5A)
Fuse 10 (7.5A)
Is the resistance of the fuse 5 ohms or less?
Yes
GO to A11 .
No
GO to A10 .
A10 TEST CIRCUIT 1003 (GY/Y) FOR A SHORT TO GROUND
Measure the resistance at Pin C210-3, Circuit 1003 (GY/Y).
Yes
REPAIR the circuit for a short to ground. TEST the system for normal operation.
No
GO to A11 .
A11 TEST CIRCUIT 1003 (GY/Y) FOR AN OPEN
Measure the resistance of Circuit 1003 (GY/Y) between the output side of Fuse 10 (7.5A) and the shift lock actuator Pin C212-3.
Yes
GO to A12 .
No
REPAIR Circuit 1003 (GY/Y) for an open. TEST the system for normal operation.
A12 TEST CIRCUIT 57 (BK) FOR AN OPEN
Measure the resistance of the shift lock actuator Pin C212-2, Circuit 57 (BK).
Yes
REPLACE the shift lock actuator. TEST the system for normal operation.
No
REPAIR Circuit 57 (BK) for an open. TEST the system for normal operation.
Matt
