2004 Ranger Lighting Question
Old Nov 17, 2005 | 02:39 PM
kkester's Avatar
kkester
I have a 2004 Ranger "Edge." I've noticed that there is no lighting behind the headlight switch. I assume that there is supposed this is supposed to be lit and may represent a burned-out bulb. Is there supposed to a light inside the glove compartment?
Kent Kester
Old Nov 17, 2005 | 05:24 PM
Ritchard1's Avatar
Ritchard1
2004 xlt here...There's lighting behind the headlight switch on mine. but there's no light inside the glove compartment (cost cutting measure, I guess).
Old Nov 17, 2005 | 05:39 PM
RangerPilot's Avatar
RangerPilot
'94 XLT regular cab. I have the glove box light, but no lighting on the light switch (it's a push pull switch so I don't guess there's a way to light it).
Old Nov 17, 2005 | 08:12 PM
kkester's Avatar
kkester
The light switch on by 2004 is more of a standard Ford turn-switch with three indicators present on the dash (off, parking lights, and full lights).
Kent Kester
Old Nov 17, 2005 | 09:04 PM
Ken00's Avatar
Ken00
Your headlight switch should have a light, get it replaced under warranty if your still covered.
Old Nov 18, 2005 | 03:26 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Does your headlight switch illumination only work when the key is in the start or run position, AND with the park or headlights turned off? Or is there headlight switch illumination regardless of the ignition key position and when the switch is in the parking or headlights on position? The schematic I'm looking at for a 2004 indicates the former. Seems rather odd.
Old Nov 18, 2005 | 03:52 AM
PW01's Avatar
PW01
It should light, have it fixed under warranty. Beware it will keep burning out, my 01 is on it's third switch.
Old Nov 18, 2005 | 04:56 AM
kkester's Avatar
kkester
Thanks. While I've enjoyed driving this truck, the overall quality as measured by warranty items is not the best--although to be fair, some of the problems have been dealer-related.
I bought the truck in January of this year. It was missing the antenna. In addition, the radio was never properly connected. The panel for the temperature controls was broken. The inside of the rear extended cab doors was not completely painted (both sides).
Kent Kester
Old Nov 18, 2005 | 08:08 AM
irvinf's Avatar
irvinf
Repacement bulb
Believe the bulb in the switch can be replaced like the one used in the
fog light switch.
Do a search to obtain more details,
Irvinf
Old Nov 18, 2005 | 08:10 AM
Oregon497's Avatar
Oregon497
I have a 2004 Edge myself and mine has a dim light behind the headlight switch
Old Nov 18, 2005 | 08:20 AM
kkester's Avatar
kkester
Thanks.
Any idea on the glove compartment? Should there be a light when it opens?
Kent Kester
Old Nov 18, 2005 | 08:48 AM
B C fx4 Level II's Avatar
B C fx4 Level II
My 2003 Ranger has a glove compartment light that works. Get everything fixed before your Bumper to Bumper Warranty runs out, you'll be glad you did.
Old Nov 18, 2005 | 09:49 AM
2004_FX4's Avatar
2004_FX4
Originally Posted by kkester
Thanks.
Kent Kester
Nope. It was removed in 2004MY as a cost cutting change.
Old Nov 18, 2005 | 12:58 PM
CowboyBilly9Mile
No glove box light in my 04. I plan on adding it; I would like to think that an Explorer light assembly will fit and that the wiring is there for it. Unless it was deemed too expensive to leave that strand of wire and the little plug in there too .
It would have been nice to also leave in the:
*cargo light
*underhood light
*map lights
*two tone rear lights, red for lights and yellow for turn lights
Old Nov 18, 2005 | 07:17 PM
35l911's Avatar
35l911
my lighted light switch bulb burned out last month
