Sponsored by: Real Truck
Air Recirculation question?
Old Nov 17, 2005 | 06:27 AM
05_F250's Avatar
05_F250
I have an 05 F250 6.0L w/out the Electronic automatic temperature control — EATC.
I don't have an option to recirculate the air inside the cab unless I am on Max AC, and for some reason that starts blowing out semi cool air even with the temp dial set to hot. After reading the manual I stopped by the dealer and asked them how to do it and they had no clue.
Any idea's. I am not too impressed with pulling fresh air on all heat settings!!!
Old Nov 17, 2005 | 06:59 AM
Casey's Avatar
Casey
If you find a way to recirculate air when using the heat settings you will find that your windows will fog. The fresh air keeps the humidity down.
Old Nov 17, 2005 | 01:49 PM
ag-ford-4x4's Avatar
ag-ford-4x4
What do you mean? You do not have a 'MAX AC" button on that truck....
Old Nov 17, 2005 | 06:10 PM
99_EB_EXPY's Avatar
99_EB_EXPY
Try the floor setting, on my expedition with EATC it recirculates on max air and floor. My F350 has manual controls, so I don't know for sure if floor setting will work on the F350 EATC or not, but it's worth a try.
Old Nov 17, 2005 | 07:27 PM
scole250's Avatar
scole250
If the Heat/AC is in "auto" mode you won't notice a difference when the recirculate is on. When in auto mode, you have to have the fan on all the way for recirculate to kick in too. If you press one of the "manual" mode buttons that directs the air to specific vent outlets, then you can manually control the recirculate function and will notice an increase in air output when the "recirculate" button is on.
Old Nov 17, 2005 | 07:56 PM
4X4 IN REFUGIO's Avatar
4X4 IN REFUGIO
As Far As I Know The Only Way To Recirculate Inside Air Is On The Max A/c Setting.
All Other Settings Should Draw Air In From The Out Side. Thats Just The Way It Is Unless You Rig It To Do Otherwise.
Big-Red-Lariat
2015 - 2020 F150
Apr 16, 2016 10:14 PM
Ian123
Aug 17, 2011 11:25 PM
Buck 1
2009 - 2014 F150
Feb 4, 2011 06:53 PM
afc2001
2004 - 2008 F150
Oct 18, 2009 09:38 PM
scole250
Jul 29, 2005 05:52 PM
