Please Help
Old Nov 16, 2005 | 09:23 PM
bldr018's Avatar
bldr018
Please Help
OK i noticed when i got home that my degas bottle was leakin coolant. Either it or the top, does anyone know why?
Old Nov 16, 2005 | 09:27 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
It's got a pressure cap...just like a radiator cap. Maybe it's bad.
Old Nov 16, 2005 | 09:31 PM
bldr018's Avatar
bldr018
thank you it sprayed everywhere and this should fix it?
Old Nov 16, 2005 | 09:32 PM
dagren99's Avatar
dagren99
Degas Bottle
Check the degas bottle for hairline cracks - I just replaced mine - it was leaking from a crack near one of the moldline seams.
DG
Old Nov 16, 2005 | 09:33 PM
cookie88's Avatar
cookie88
FTE Emeritus
If that's the problem it will. How much coolant did you lose? It didn't overheat and spray everyting down like a blown hose did it?
Old Nov 16, 2005 | 09:44 PM
bldr018's Avatar
bldr018
there is some on the battery next to the bottle why, would that be a bad thing?
Old Nov 17, 2005 | 09:54 PM
cookie88's Avatar
cookie88
FTE Emeritus
Yeah, it would be bad if a hose popped....you would lose all of your coolant and overheat the engine. I'm assuming that didn't happen since it seems you just have a small leak that's making a bit of a mess.
Since your degas is evidently still mostly full it's just a matter of tracking down the leak and fixing it.
russellkr
Nov 2, 2002 11:18 AM
beartracks
Oct 18, 2002 02:20 PM
dale i
Sep 22, 2002 09:37 AM
rogwelch
Feb 12, 2000 11:29 PM
Jan 28, 2000 06:08 PM
