Instrument cluster self test
Old 11-16-2005, 06:19 AM
DZari's Avatar
DZari
DZari is offline
On my '05 F-250 gasser I have accessed the instrument cluster self test mode and found some DTC's. Does anyone know where explanations for these DTC's can be found? i.e. - 9352, 9360, 9318
Old 11-16-2005, 01:28 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,737 Likes on 1,407 Posts
Here's the DTC's for 2003
DTC Description Source Action
B1201 Fuel Sender Circuit Failure HEC
B1201 Fuel Sender Circuit Failure OTC
B1203 Fuel Sender Circuit Short to Battery OTC
B1204 Fuel Sender Circuit Short to Ground HEC
B1205 EIC Switch-1 Assembly Failure HEC
B1208 EIC Switch-1 Assembly Circuit Short to Ground OTC
B1213 Anti-Theft Number of Programmed Encoded Ignition Keys Below Minimum PATS
B1217 Horn Relay Coil Circuit Failure VSM
B1231 Longitudinal Acceleration Threshold Exceeded RCM
B1232 Antenna Not Connected Defective Transceiver PATS
B1251 Air Temperature Internal Sensor Circuit Open EATC Module
B1253 Air Temperature Internal Sensor Short to Ground EATC Module
B1255 Air Temperature External Sensor Circuit Open EATC Module
B1255 Air Temperature External Sensor Circuit Open OTC
B1257 Air Temperature External Sensor Circuit Short to Ground EATC Module
B1259 Solar Radiation Sensor Circuit Open EATC Module
B1261 Solar Radiation Sensor Circuit Short to Ground EATC Module
B1299 Power Supply Sensor Circuit Short to Ground Parking Aid Module
B1300 Power Door Lock Circuit Failure VSM
B1311 Power Door Unlock Circuit Failure VSM
B1317 Battery Voltage High VSM
B1317 Battery Voltage Low Rear Air Suspension Control Module
B1317 Battery Voltage High HEC
B1317 Battery Voltage High 4x4 Module
B1318 Battery Voltage Low VSM
B1318 Battery Voltage High Rear Air Suspension Control Module
B1318 Battery Voltage Low 4x4 Module
B1318 Battery Voltage Low HEC
B1318 Battery Voltage Low RCM
B1320 Driver Door Ajar Circuit Open HEC
B1321 Driver Door Ajar Circuit Short to Battery VSM
B1328 Passenger Door Ajar Circuit Open HEC
B1329 Passenger Door Ajar Circuit Short to Battery VSM
B1333 Decklid Ajar Rear Door Circuit Short to Battery VSM
B1337 Door Ajar RR Circuit Short to Battery VSM
B1342 ECU is Defective ABS CLEAR DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new ABS module.
B1342 ECU is Defective 4x4 Module CLEAR DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new 4x4 module.
B1342 ECU is Defective OTC CLEAR DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new OTC module.
B1342 ECU is Defective Parking Aid Module CLEAR DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new parking aid module.
B1342 ECU is Defective VSM CLEAR DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new VSM,
B1342 ECU is Defective RCM CLEAR DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new RCM.
B1342 ECU is Defective Rear Air Suspension Control Module CLEAR DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new rear air suspension control module.
B1342 ECU is Defective HEC CLEAR DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new HEC.
B1342 ECU is Defective EATC Module CLEAR DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new EATC module.
B1342 ECU is Defective DSM Module CLEAR DTCs. REPEAT the self-test. Tf DTC B1342 is retrieved, INSTALL a new DSM module.
B1345 Heated Backlight Input Circuit Short to Ground HEC
B1352 Ignition Key-In Circuit Failure HEC
B1355 Ignition RUN Circuit Failure 4x4 Module
B1359 Ignition RUN/ACC Circuit Failure 4x4 Module
B1360 Ignition RUN/ACC Circuit Open HEC
B1366 Ignition START Circuit Short to Ground 4x4 Module
B1483 Brake Pedal Input Circuit Failure 4x4 Module
B1485 Brake Pedal Input Circuit Short to Battery 4x4 Module
B1500 Lamp Turn Signal Left Circuit Open and Short to Battery VSM
B1501 Lamp Turn Signal Left Circuit Short to Battery VSM
B1504 Lamp Turn Signal Right Circuit Open and Short to Battery VSM
B1505 Lamp Turn Signal Right Circuit Short to Battery VSM
B1521 Hood Switch Circuit Short to Battery VSM
B1529 Memory Set Switch Short to Ground DSM
B1534 Memory 1 Switch Circuit Short to Ground DSM
B1538 Memory 2 Switch Circuit Short to Ground DSM
B1573 Door Ajar LR Circuit Short to Battery VSM
B1600 No Key Code Received - Damaged Encoded Ignition Key or Use of Non-PATS Encoded Ignition Key PATS
B1601 PATS Received Incorrect Key Code From Ignition Key Transponder PATS
B1602 PATS Received Invalid Format of Key Code From Ignition Key Transponder PATS
B1629 PRNDL Reverse Input Short to Battery Parking Aid Module
B1663 Driver Seat Front Up/Down Motor Stalled DSM
B1664 Driver Seat Rear Up/Down Motor Stalled DSM
B1665 Driver Seat Forward Backward Motor Stalled DSM
B1666 Seat Recline Forward/Rearward Motor Stalled DSM
B1676 Battery Voltage Out of Range EATC Module
B1676 Battery Voltage Out of Range DSM
B1676 Supply Voltage Out of Range ABS
B1681 PATS Transceiver Signal Is Not Received (Not Connected, Damaged or Wiring) PATS
B1695 Autolamp On Circuit Failure VSM
B1703 Seat Driver Recline Forward Switch Circuit Short to Battery DSM
B1707 Seat Driver Recline Rearward Switch Circuit Short to Battery DSM
B1711 Driver Seat Front Up Switch Circuit Short to Battery DSM
B1715 Driver Seat Front Down Switch Circuit Short to Battery DSM
B1719 Driver Seat Forward Switch Circuit Short to Battery DSM
B1723 Driver Seat Rearward Switch Circuit Short to Battery DSM
B1727 Driver Seat Rear Up Switch Circuit Short to Battery DSM
B1731 Driver Seat Rear Down Switch Circuit Short to Battery DSM
B1792 Autolamp Sensor Input Circuit Short to Battery and Open VSM
B1793 Autolamp Sensor Input Circuit Short to Ground VSM
B1869 Air Bag Lamp Warning Indicator Circuit Open RCM
B1870 Air Bag Lamp Warning Indicator Circuit Short to Battery RCM
B1871 Passenger Air Bag Deactivate Module Fault RCM
B1877 Seatbelt Driver Pretensioner Circuit Open RCM
B1878 Seatbelt Driver Pretensioner Circuit Short to Battery RCM
B1879 Seatbelt Driver Pretensioner Circuitry Short to Ground RCM
B1881 Seatbelt Passenger Pretensioner Circuit Open RCM
B1882 Seatbelt Passenger Pretensioner Circuit Short to Battery RCM
B1883 Seatbelt Passenger Pretensioner Short to Ground RCM
B1884 PAD Warning Lamp Inoperative RCM
B1885 Seatbelt Driver Pretensioner Circuit Resistance Low on Squib RCM
B1886 Seatbelt Passenger Pretensioner Circuit Resistance Low on Squib RCM
B1887 Driver Air Bag Circuit Short to Ground RCM
B1888 Passenger Air Bag Circuit Short to Ground RCM
B1889 Passenger Air Bag Deactivate Module Sensor Obstructed RCM
B1890 PAD Warning Lamp Circuit Short to Battery RCM
B1891 Air Bag Tone Warning Indicator Circuit Short to Battery RCM
B1892 Air Bag Tone Warning Indicator Circuit Failure RCM
B1901 Air Bag Crash No. 1 Feed/Return Circuit Short to Ground RCM
B1916 Driver Air Bag Circuit Short to Battery RCM
B1921 Air Bag Diagnostic Monitor Ground Circuit Open RCM
B1925 Passenger Air Bag Circuit Short to Battery RCM
B1932 Driver Air Bag Circuit Open RCM
B1933 Passenger Air Bag Circuit Open RCM
B1934 Driver Air Bag Inflator Circuit Resistance Low on Squib RCM
B1935 Passenger Air Bag Inflator Circuit Resistance Low on Squib RCM
B1941 Air Bag Crash No. 1 Feed/Return Circuit Open RCM
B1950 Seat Rear Up/Down Potentiometer Feedback Circuit Failure DSM
B1952 Seat Rear Up/Down Potentiometer Feedback Circuit Short to Battery DSM
B1954 Seat Front Up/Down Potentiometer Feedback Circuit Failure DSM
B1956 Seat Front Up/Down Potentiometer Feedback Circuit Short to Battery DSM
B1958 Seat Recline Forward/Backward Feedback Potentiometer Circuit Failure DSM
B1961 Seat Recline Forward/Backward Feedback Potentiometer Circuit Short to Ground DSM
B1962 Seat Horizontal Forward/Rearward Potentiometer Feedback Circuit Failure DSM
B1964 Seat Horizontal Forward/Rearward Potentiometer Feedback Circuit Short to Battery DSM
B1987 Pedal Forward/Rearward Motor Stalled DSM
B1988 Pedal Position Forward Switch Short to Battery DSM
B1989 Pedal Position Rearward Switch Short to Battery DSM
B1992 Driver Side, Side Mount Air Bag Circuit Short to Battery RCM
B1993 Driver Side, Side Mount Air Bag Circuit Short to Ground RCM
B1994 Driver Side, Side Mount Air Bag Circuit Open RCM
B1995 Driver Side, Side Mount Air Bag Circuit Resistance Low on Squib RCM
B1996 Passenger Side, Side Mount Air Bag Circuit Short to Battery RCM
B1997 Passenger Side, Side Mount Air Bag Circuit Short to Ground RCM
B1998 Passenger Side, Side Mount Air Bag Circuit Open RCM
B1999 Passenger Side, Side Mount Air Bag Circuit Resistance Low on Squib RCM
B2002 ECU Body and Assembly Testing Incomplete Rear Air Suspension Control Module
B2103 Antenna Not Connected Defective Transceiver PATS
B2112 Door Driver Set Switch Failure VSM
B2116 Door Driver Reset Switch Failure VSM
B2139 PCM ID Does Not Match Between PATS and PCM PATS
B2140 Initialization Failure Rear Air Suspension Control module
B2141 NVM Configuration Failure PATS
B2143 NVM Memory Failure HEC
B2148 PWM Input Circuit Failure OTC
B2177 IS Sense Circuit Failure VSM
B2266 Blend Door Circuit Failure EATC Module
B2276 Less Than Two Transmitters Programmed VSM
B2373 LED No. 1 Circuit Short to Battery Parking Aid Module
B2425 Remote Keyless Entry Out of Synchronization VSM
B2432 Driver Seat Belt Buckle Switch Circuit Open RCM
B2434 Driver Seat Belt Buckle Switch Circuit Short to Ground RCM
B2435 Driver Seat Belt Buckle Switch Circuit Resistance Out of Ranger RCM
B2436 Passenger Seat Belt Buckle Switch Circuit Open RCM
B2438 Passenger Sealt Belt Buckle Switch Circuit Short to Ground RCM
Old 11-16-2005, 01:30 PM
Franklin2's Avatar
Franklin2
B2439 Passenger Seat Belt Buckle Switch Circuit Resistance Out of Range RCM
B2440 Passenger Side, Side Crash Sensor Mount Fault RCM
B2441 Driver Side, Side Crash Sensor Mount Fault RCM
B2444 Driver Side Crash Sensor Internal Fault RCM
B2445 Passenger Side Crash Sensor Internal Fault RCM
B2476 Radio Sense Input Circuit Failure VSM
B2477 Module Configuration Fault VSM
B2477 Module Configuration Failure (Unconfigured, Incorrect, or Rejected) ABS
B2477 Module Configuration Failure (Unconfigured, Incorrect or Rejected) 4x4 Module
B2477 Module Configuration Failure (Unconfigured, Incorrect or Rejected) OTC
B2477 Module Configuration Failure (Unconfigured, Incorrect or Rejected) Parking Aid Module
B2477 Module Configuration Failure (Unconfigured, Incorrect or Rejected) Rear Air Suspension Control Module
B2477 Module Configuration Failure (Unconfigured, Incorrect or Rejected) RCM
B2477 Module Configuration Failure (Unconfigured, Incorrect or Rejected) HEC
B2477 Module Configuration Failure RCM
B2477 Module Configuration Failure DSM
B2658 Wait to Start Warning Indicator Circuit Open HEC
B2661 Parklamp Relay Output Short to Battery VSM
B2662 Parklamp Relay Output Open Circuit VSM
B2663 Headlamp Relay Output Short to Battery VSM
B2664 Headlamp Relay Output Open Circuit or Short to Battery VSM
B2666 Liftgate Release Switch Circuit Failure VSM
B2667 Liftglass Release Switch Circuit Failure VSM
B2669 Liftgate Release Relay Coil Failure VSM
B2675 Keypad B Switch Circuit Failure VSM
B2676 Keypad C Switch Circuit Failure VSM
B2695 Keypad A Switch Circuit Failure VSM
B2794 Third Row Power Folding Seat Circuit Failure VSM
C1095 ABS Hydraulic Pump Motor Circuit Failure ABS
C1096 ABS Hydraulic Pump Motor Circuit Open ABS
C1145 Wheel Speed Sensor RF Input Circuit Failure ABS
C1147 Vehicle Speed Sensor Input Short to Ground OTC
C1148 Wheel Speed Sensor RF Coherency Fault ABS
C1155 Wheel Speed Sensor LF Input Circuit Failure ABS
C1158 Wheel Speed Sensor LF Coherency Fault ABS
C1169 ABS Fluid Dumping Exceeds Maximum Timing ABS
C1184 ABS System is Not Operational ABS
C1185 ABS Power Relay Output Circuit Failure ABS
C1194 ABS Outlet Valve Coil LF Circuit Failure ABS
C1196 ABS Outlet Valve Coil LF Circuit Short to Battery ABS
C1198 ABS Inlet Valve Coil LF Circuit Failure ABS
C1200 ABS Inlet Valve Coil LF Circuit Short to Battery ABS
C1202 ABS Outlet (Dump) Valve Coil Rear Circuit Failure ABS
C1204 ABS Outlet (Dump) Valve Coil Rear Circuit Short to Battery ABS
C1206 ABS Inlet (Isolation) Valve Coil Rear Circuit Failure ABS
C1208 ABS Inlet (Isolation) Valve Coil Rear Circuit ABS
C1210 ABS Outlet Valve Coil RF Circuit Failure ABS
C1212 ABS Outlet Valve Coil RF Circuit Short to Battery ABS
C1214 ABS Inlet Valve Coil RF Circuit Failure ABS
C1216 ABS Inlet Valve Coil RF Circuit Short to Battery ABS
C1222 Wheel Speed Mismatch ABS
C1226 Lamp Brake Warning Output Short to Ground ABS
C1229 Wheel Speed Sensor Rear Center Coherency Fault ABS
C1230 Wheel Speed Sensor Rear Center Input Circuit Failure ABS
C1233 Wheel Speed LF Input Signal Missing ABS
C1234 Wheel Speed RF Input Signal Missing ABS
C1237 Wheel Speed Rear Input Signal Missing ABS
C1284 Oil Pressure Switch Failure HEC
C1414 Incorrect Module Design Level RCM
C1503 Right Front Isolation Diode ABS
C1503 Left Front Isolation Diode ABS
C1699 Rear Outer Left Sensor Circuit Short to Battery Parking Aid Module
C1700 Rear Outer Left Sensor Circuit Failure Parking Aid Module
C1701 Rear Outer Left Sensor Fault Parking Aid Module
C1702 Rear Outer Right Sensor Circuit Short to Battery Parking Aid Module
C1703 Rear Outer Right Sensor Circuit Failure Parking Aid Module
C1704 Rear Outer Right Sensor Fault Parking Aid Module
C1705 Rear Inner Left Sensor Circuit Short to Battery Parking Aid Module
C1706 Rear Inner Left Sensor Circuit Failure Parking Aid Module
C1707 Rear Inner Left Sensor Fault Parking Aid Module
C1708 Rear Inner Right Sensor Circuit Short to Battery Parking Aid Module
C1709 Rear Inner Right Sensor Circuit Failure Parking Aid Module
C1710 Rear Inner Right Sensor Fault Parking Aid Module
C1726 Air Suspension Pneumatic Failure Rear Air Suspension Control Module
C1728 Transfer Case Unable to Transition Between 2H and 4H 4x4 Module
C1729 Transfer Case Unable to Transition Between 4H and 4L 4x4 Module
C1742 Rear Sounder Circuit Failure Parking Aid Module
C1743 Rear Sounder Circuit Short to Battery Parking Aid Module
C1748 Switch Input Circuit Short to Ground Parking Aid Module
C1770 Air Suspension Vent Solenoid Circuit Failure Rear Air Suspension Control Module
C1790 Air Suspension LR Air Spring Solenoid Output Circuit Failure Rear Air Suspension Control Module
C1795 Air Suspension RR Air Spring Solenoid Output Circuit Failure Rear Air Suspension Control Module
C1809 Air Suspension Vent Timeout Rear Air Suspension Control Module
C1810 Air Suspension Height Sensor Out Of Range Rear Air Suspension Control Module
C1811 Air Suspension Return to Trim Timeout Rear Air Suspension Control Module
C1812 Air Suspension Height Sensor Failure Rear Air Suspension Control Module
C1820 Air Suspension Air Compressor Request Exceeded Maximum Time Rear Air Suspension Control Module
C1830 Air Suspension Compressor Relay Circuit Failure Rear Air Suspension Control Module
C1920 LED No.1 Circuit Short to Ground Parking Aid Module
C1972 Air Suspension Kneel Switch Circuit Failure Rear Air Suspension Control Module
C1974 Air Reservoir Filling Error Rear Air Suspension Control Module
C1993 Air Suspension Pressure Sensor Circuit Failure Rear Air Suspension Control Module
C1995 Air Suspension Moisture Ejector Valve Circuit Failure Rear Air Suspension Control Module
P0500 Vehicle Speed Sensor (VSS) Malfunction 4x4 Module
P1139 Water in Fuel Warning Indicator Circuit Malfunction HEC
P0500 Vehicle Speed Sensor (VSS) Malfunction OTC
P1804 Transmission 4-Wheel Drive High Indicator Circuit Failure 4x4 Module
P1806 Transmission 4-Wheel Drive High Indicator Short 4x4 Module
P1808 Transmission 4-Wheel Drive Low Indicator Circuit Failure 4x4 Module
P1810 Transmission 4-Wheel Drive Low Indicator Short 4x4 Module
P1812 Transmission 4-Wheel Drive Mode Select Circuit Failure 4x4 Module
P1815 Transmission 4-Wheel Drive Mode Select Short 4x4 Module
P1819 Transmission Neutral Safety Switch Short Circuit to Ground 4x4 Module
P1820 Transmission Transfer Case Clockwise Shift Relay 4x4 Module
P1822 Transmission Transfer Case Clockwise Shift Relay Coil 4x4 Module
P1828 Transmission Transfer Case Counterclockwise Shift 4x4 Module
P1830 Transmission Transfer Case Counterclockwise Shift 4x4 Module
P1832 Transmission Transfer Case Differential Lock-Up 4x4 Module
P1834 Transmission Transfer Case Differential Lock-Up 4x4 Module
P1865 Transmission Transfer Case Contact Plate Power 4x4 Module
P1866 Transmission Transfer Case System Concern 4x4 Module
P1867 Transmission Transfer Case Contact Plate General 4x4 Module
P1876 Transmission Transfer Case 2-Wheel Drive Solenoid Circuit Failure 4x4 Module
P1877 Transmission Transfer Case 2-Wheel Drive Solenoid Circuit Short 4x4 Module
U1027 SCP (J1850) Invalid or Missing Data for Engine RPM HEC
U1058 SCP (J1850) Invalid or Missing Data for Transmission Fluid Temp HEC
U1059 SCP (J1850) Invalid or Missing Data for Transmission/Transaxle PRNDL HEC
U1073 SCP (J1850) Invalid or Missing Data for Engine Coolant HEC
U1147 Faulty SCP Link or Incorrect PCM Calibration PATS
U1262 Missing SCP Message PATS
U1262 SCP (J1850) Communication Bus Fault HEC
U1950 UBP Communication Bus Fault VSM
U1950 UBP Communication Bus Fault HEC
U2015 Signal Link Fault (Non-SCP) OTC
U2016 Signal Link Short to Ground (Non-SCP) OTC
U2017 Driver Side Crash Sensor Communications Fault RCM
U2018 Passenger Side Crash Sensor Communications Fault RCM
U2306 UBP Invalid Data fom Node ID $60 (IC) VSM
Old 03-03-2012, 04:37 PM
ryjmon's Avatar
ryjmon
ryjmon is offline
I have a 2001 f-150 supercrew with a 5.4 4 wheel drive I have a Rear dump outlet circuit malfuction. does anyone know what that might be? Any info would be great i called Ford and they never heard of it. I called about 5 local auto part stores and they never heard of it please help. The ABS light comes on every so often then can shut off.
Old 03-03-2012, 04:57 PM
JD IN NJ's Avatar
JD IN NJ
JD IN NJ is offline
To ryjmon
Please start a new thread or a new ? Two questions in one thread makes it hard to answer
Old 03-03-2012, 08:47 PM
Franklin2's Avatar
Franklin2
What is the code? How do you know you have this fault?
Old 03-03-2012, 10:07 PM
ryjmon's Avatar
ryjmon
ryjmon is offline
I had the code scanned at a auto part store. The code is B1202. I thought it was a ABS speed sensor but i was wrong. Thanks
Old 03-04-2012, 09:04 AM
Franklin2's Avatar
Franklin2
B1202 on a 2001 f150 is a fuel sender open circuit code.
Old 03-04-2012, 12:09 PM
ryjmon's Avatar
ryjmon
ryjmon is offline
how do i go by fixing that? would that cause my ABS light to come on?
Old 03-04-2012, 03:00 PM
Franklin2's Avatar
Franklin2
No it would not. I would check the wiring back at the tank. Mice and squirrels love to chew the wiring back there and along the frame rail.
Old 03-04-2012, 05:01 PM
ryjmon's Avatar
ryjmon
ryjmon is offline
i will do some checkin thanks for the info
Old 03-04-2012, 09:37 PM
ryjmon's Avatar
ryjmon
ryjmon is offline
what would "Rear dump outlet circuit malfuction" mean?
Old 03-05-2012, 07:42 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
It probably means you looked up the code in the wrong place, i.e., not a Ford-related resource.
Does your fuel gauge work properly or not? If it does work properly, you have a bogus code.
Old 03-06-2012, 10:11 PM
ryjmon's Avatar
ryjmon
ryjmon is offline
ya my fuel gauge works just fine
Old 03-23-2012, 12:56 AM
darrengee's Avatar
darrengee
darrengee is offline
Did you get your ABS codes read at AutoZone? My ABS light is on sometimes and AutoZone hooked up their scanner and told me my codes were b1185 and b1226. But, the codes up on the second post describe my problems as c1185 and c1226. So your actual code may be a c1202. That dump valve sounds like something in the control module or pump to me.
rustyandleaking
12-30-2016 01:16 PM
wyoclint
12-15-2016 05:02 PM
A/Ox4
1999 to 2016 Super Duty
47
12-26-2011 04:42 PM
ampslw
2004 - 2008 F150
01-29-2011 07:17 AM
laka
07-30-2010 06:46 PM
Quick Reply: Instrument cluster self test
