Instrument cluster self test
On my '05 F-250 gasser I have accessed the instrument cluster self test mode and found some DTC's. Does anyone know where explanations for these DTC's can be found? i.e. - 9352, 9360, 9318
Here's the DTC's for 2003
DTC Description Source Action B1201 Fuel Sender Circuit Failure HEC B1201 Fuel Sender Circuit Failure OTC B1203 Fuel Sender Circuit Short to Battery OTC B1204 Fuel Sender Circuit Short to Ground HEC B1205 EIC Switch-1 Assembly Failure HEC B1208 EIC Switch-1 Assembly Circuit Short to Ground OTC B1213 Anti-Theft Number of Programmed Encoded Ignition Keys Below Minimum PATS B1217 Horn Relay Coil Circuit Failure VSM B1231 Longitudinal Acceleration Threshold Exceeded RCM B1232 Antenna Not Connected Defective Transceiver PATS B1251 Air Temperature Internal Sensor Circuit Open EATC Module B1253 Air Temperature Internal Sensor Short to Ground EATC Module B1255 Air Temperature External Sensor Circuit Open EATC Module B1255 Air Temperature External Sensor Circuit Open OTC B1257 Air Temperature External Sensor Circuit Short to Ground EATC Module B1259 Solar Radiation Sensor Circuit Open EATC Module B1261 Solar Radiation Sensor Circuit Short to Ground EATC Module B1299 Power Supply Sensor Circuit Short to Ground Parking Aid Module B1300 Power Door Lock Circuit Failure VSM B1311 Power Door Unlock Circuit Failure VSM B1317 Battery Voltage High VSM B1317 Battery Voltage Low Rear Air Suspension Control Module B1317 Battery Voltage High HEC B1317 Battery Voltage High 4x4 Module B1318 Battery Voltage Low VSM B1318 Battery Voltage High Rear Air Suspension Control Module B1318 Battery Voltage Low 4x4 Module B1318 Battery Voltage Low HEC B1318 Battery Voltage Low RCM B1320 Driver Door Ajar Circuit Open HEC B1321 Driver Door Ajar Circuit Short to Battery VSM B1328 Passenger Door Ajar Circuit Open HEC B1329 Passenger Door Ajar Circuit Short to Battery VSM B1333 Decklid Ajar Rear Door Circuit Short to Battery VSM B1337 Door Ajar RR Circuit Short to Battery VSM B1342 ECU is Defective ABS CLEAR DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new ABS module. B1342 ECU is Defective 4x4 Module CLEAR DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new 4x4 module. B1342 ECU is Defective OTC CLEAR DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new OTC module. B1342 ECU is Defective Parking Aid Module CLEAR DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new parking aid module. B1342 ECU is Defective VSM CLEAR DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new VSM, B1342 ECU is Defective RCM CLEAR DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new RCM. B1342 ECU is Defective Rear Air Suspension Control Module CLEAR DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new rear air suspension control module. B1342 ECU is Defective HEC CLEAR DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new HEC. B1342 ECU is Defective EATC Module CLEAR DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new EATC module. B1342 ECU is Defective DSM Module CLEAR DTCs. REPEAT the self-test. Tf DTC B1342 is retrieved, INSTALL a new DSM module. B1345 Heated Backlight Input Circuit Short to Ground HEC B1352 Ignition Key-In Circuit Failure HEC B1355 Ignition RUN Circuit Failure 4x4 Module B1359 Ignition RUN/ACC Circuit Failure 4x4 Module B1360 Ignition RUN/ACC Circuit Open HEC B1366 Ignition START Circuit Short to Ground 4x4 Module B1483 Brake Pedal Input Circuit Failure 4x4 Module B1485 Brake Pedal Input Circuit Short to Battery 4x4 Module B1500 Lamp Turn Signal Left Circuit Open and Short to Battery VSM B1501 Lamp Turn Signal Left Circuit Short to Battery VSM B1504 Lamp Turn Signal Right Circuit Open and Short to Battery VSM B1505 Lamp Turn Signal Right Circuit Short to Battery VSM B1521 Hood Switch Circuit Short to Battery VSM B1529 Memory Set Switch Short to Ground DSM B1534 Memory 1 Switch Circuit Short to Ground DSM B1538 Memory 2 Switch Circuit Short to Ground DSM B1573 Door Ajar LR Circuit Short to Battery VSM B1600 No Key Code Received - Damaged Encoded Ignition Key or Use of Non-PATS Encoded Ignition Key PATS B1601 PATS Received Incorrect Key Code From Ignition Key Transponder PATS B1602 PATS Received Invalid Format of Key Code From Ignition Key Transponder PATS B1629 PRNDL Reverse Input Short to Battery Parking Aid Module B1663 Driver Seat Front Up/Down Motor Stalled DSM B1664 Driver Seat Rear Up/Down Motor Stalled DSM B1665 Driver Seat Forward Backward Motor Stalled DSM B1666 Seat Recline Forward/Rearward Motor Stalled DSM B1676 Battery Voltage Out of Range EATC Module B1676 Battery Voltage Out of Range DSM B1676 Supply Voltage Out of Range ABS B1681 PATS Transceiver Signal Is Not Received (Not Connected, Damaged or Wiring) PATS B1695 Autolamp On Circuit Failure VSM B1703 Seat Driver Recline Forward Switch Circuit Short to Battery DSM B1707 Seat Driver Recline Rearward Switch Circuit Short to Battery DSM B1711 Driver Seat Front Up Switch Circuit Short to Battery DSM B1715 Driver Seat Front Down Switch Circuit Short to Battery DSM B1719 Driver Seat Forward Switch Circuit Short to Battery DSM B1723 Driver Seat Rearward Switch Circuit Short to Battery DSM B1727 Driver Seat Rear Up Switch Circuit Short to Battery DSM B1731 Driver Seat Rear Down Switch Circuit Short to Battery DSM B1792 Autolamp Sensor Input Circuit Short to Battery and Open VSM B1793 Autolamp Sensor Input Circuit Short to Ground VSM B1869 Air Bag Lamp Warning Indicator Circuit Open RCM B1870 Air Bag Lamp Warning Indicator Circuit Short to Battery RCM B1871 Passenger Air Bag Deactivate Module Fault RCM B1877 Seatbelt Driver Pretensioner Circuit Open RCM B1878 Seatbelt Driver Pretensioner Circuit Short to Battery RCM B1879 Seatbelt Driver Pretensioner Circuitry Short to Ground RCM B1881 Seatbelt Passenger Pretensioner Circuit Open RCM B1882 Seatbelt Passenger Pretensioner Circuit Short to Battery RCM B1883 Seatbelt Passenger Pretensioner Short to Ground RCM B1884 PAD Warning Lamp Inoperative RCM B1885 Seatbelt Driver Pretensioner Circuit Resistance Low on Squib RCM B1886 Seatbelt Passenger Pretensioner Circuit Resistance Low on Squib RCM B1887 Driver Air Bag Circuit Short to Ground RCM B1888 Passenger Air Bag Circuit Short to Ground RCM B1889 Passenger Air Bag Deactivate Module Sensor Obstructed RCM B1890 PAD Warning Lamp Circuit Short to Battery RCM B1891 Air Bag Tone Warning Indicator Circuit Short to Battery RCM B1892 Air Bag Tone Warning Indicator Circuit Failure RCM B1901 Air Bag Crash No. 1 Feed/Return Circuit Short to Ground RCM B1916 Driver Air Bag Circuit Short to Battery RCM B1921 Air Bag Diagnostic Monitor Ground Circuit Open RCM B1925 Passenger Air Bag Circuit Short to Battery RCM B1932 Driver Air Bag Circuit Open RCM B1933 Passenger Air Bag Circuit Open RCM B1934 Driver Air Bag Inflator Circuit Resistance Low on Squib RCM B1935 Passenger Air Bag Inflator Circuit Resistance Low on Squib RCM B1941 Air Bag Crash No. 1 Feed/Return Circuit Open RCM B1950 Seat Rear Up/Down Potentiometer Feedback Circuit Failure DSM B1952 Seat Rear Up/Down Potentiometer Feedback Circuit Short to Battery DSM B1954 Seat Front Up/Down Potentiometer Feedback Circuit Failure DSM B1956 Seat Front Up/Down Potentiometer Feedback Circuit Short to Battery DSM B1958 Seat Recline Forward/Backward Feedback Potentiometer Circuit Failure DSM B1961 Seat Recline Forward/Backward Feedback Potentiometer Circuit Short to Ground DSM B1962 Seat Horizontal Forward/Rearward Potentiometer Feedback Circuit Failure DSM B1964 Seat Horizontal Forward/Rearward Potentiometer Feedback Circuit Short to Battery DSM B1987 Pedal Forward/Rearward Motor Stalled DSM B1988 Pedal Position Forward Switch Short to Battery DSM B1989 Pedal Position Rearward Switch Short to Battery DSM B1992 Driver Side, Side Mount Air Bag Circuit Short to Battery RCM B1993 Driver Side, Side Mount Air Bag Circuit Short to Ground RCM B1994 Driver Side, Side Mount Air Bag Circuit Open RCM B1995 Driver Side, Side Mount Air Bag Circuit Resistance Low on Squib RCM B1996 Passenger Side, Side Mount Air Bag Circuit Short to Battery RCM B1997 Passenger Side, Side Mount Air Bag Circuit Short to Ground RCM B1998 Passenger Side, Side Mount Air Bag Circuit Open RCM B1999 Passenger Side, Side Mount Air Bag Circuit Resistance Low on Squib RCM B2002 ECU Body and Assembly Testing Incomplete Rear Air Suspension Control Module B2103 Antenna Not Connected Defective Transceiver PATS B2112 Door Driver Set Switch Failure VSM B2116 Door Driver Reset Switch Failure VSM B2139 PCM ID Does Not Match Between PATS and PCM PATS B2140 Initialization Failure Rear Air Suspension Control module B2141 NVM Configuration Failure PATS B2143 NVM Memory Failure HEC B2148 PWM Input Circuit Failure OTC B2177 IS Sense Circuit Failure VSM B2266 Blend Door Circuit Failure EATC Module B2276 Less Than Two Transmitters Programmed VSM B2373 LED No. 1 Circuit Short to Battery Parking Aid Module B2425 Remote Keyless Entry Out of Synchronization VSM B2432 Driver Seat Belt Buckle Switch Circuit Open RCM B2434 Driver Seat Belt Buckle Switch Circuit Short to Ground RCM B2435 Driver Seat Belt Buckle Switch Circuit Resistance Out of Ranger RCM B2436 Passenger Seat Belt Buckle Switch Circuit Open RCM B2438 Passenger Sealt Belt Buckle Switch Circuit Short to Ground RCM |
B2439 Passenger Seat Belt Buckle Switch Circuit Resistance Out of Range RCM
B2440 Passenger Side, Side Crash Sensor Mount Fault RCM B2441 Driver Side, Side Crash Sensor Mount Fault RCM B2444 Driver Side Crash Sensor Internal Fault RCM B2445 Passenger Side Crash Sensor Internal Fault RCM B2476 Radio Sense Input Circuit Failure VSM B2477 Module Configuration Fault VSM B2477 Module Configuration Failure (Unconfigured, Incorrect, or Rejected) ABS B2477 Module Configuration Failure (Unconfigured, Incorrect or Rejected) 4x4 Module B2477 Module Configuration Failure (Unconfigured, Incorrect or Rejected) OTC B2477 Module Configuration Failure (Unconfigured, Incorrect or Rejected) Parking Aid Module B2477 Module Configuration Failure (Unconfigured, Incorrect or Rejected) Rear Air Suspension Control Module B2477 Module Configuration Failure (Unconfigured, Incorrect or Rejected) RCM B2477 Module Configuration Failure (Unconfigured, Incorrect or Rejected) HEC B2477 Module Configuration Failure RCM B2477 Module Configuration Failure DSM B2658 Wait to Start Warning Indicator Circuit Open HEC B2661 Parklamp Relay Output Short to Battery VSM B2662 Parklamp Relay Output Open Circuit VSM B2663 Headlamp Relay Output Short to Battery VSM B2664 Headlamp Relay Output Open Circuit or Short to Battery VSM B2666 Liftgate Release Switch Circuit Failure VSM B2667 Liftglass Release Switch Circuit Failure VSM B2669 Liftgate Release Relay Coil Failure VSM B2675 Keypad B Switch Circuit Failure VSM B2676 Keypad C Switch Circuit Failure VSM B2695 Keypad A Switch Circuit Failure VSM B2794 Third Row Power Folding Seat Circuit Failure VSM C1095 ABS Hydraulic Pump Motor Circuit Failure ABS C1096 ABS Hydraulic Pump Motor Circuit Open ABS C1145 Wheel Speed Sensor RF Input Circuit Failure ABS C1147 Vehicle Speed Sensor Input Short to Ground OTC C1148 Wheel Speed Sensor RF Coherency Fault ABS C1155 Wheel Speed Sensor LF Input Circuit Failure ABS C1158 Wheel Speed Sensor LF Coherency Fault ABS C1169 ABS Fluid Dumping Exceeds Maximum Timing ABS C1184 ABS System is Not Operational ABS C1185 ABS Power Relay Output Circuit Failure ABS C1194 ABS Outlet Valve Coil LF Circuit Failure ABS C1196 ABS Outlet Valve Coil LF Circuit Short to Battery ABS C1198 ABS Inlet Valve Coil LF Circuit Failure ABS C1200 ABS Inlet Valve Coil LF Circuit Short to Battery ABS C1202 ABS Outlet (Dump) Valve Coil Rear Circuit Failure ABS C1204 ABS Outlet (Dump) Valve Coil Rear Circuit Short to Battery ABS C1206 ABS Inlet (Isolation) Valve Coil Rear Circuit Failure ABS C1208 ABS Inlet (Isolation) Valve Coil Rear Circuit ABS C1210 ABS Outlet Valve Coil RF Circuit Failure ABS C1212 ABS Outlet Valve Coil RF Circuit Short to Battery ABS C1214 ABS Inlet Valve Coil RF Circuit Failure ABS C1216 ABS Inlet Valve Coil RF Circuit Short to Battery ABS C1222 Wheel Speed Mismatch ABS C1226 Lamp Brake Warning Output Short to Ground ABS C1229 Wheel Speed Sensor Rear Center Coherency Fault ABS C1230 Wheel Speed Sensor Rear Center Input Circuit Failure ABS C1233 Wheel Speed LF Input Signal Missing ABS C1234 Wheel Speed RF Input Signal Missing ABS C1237 Wheel Speed Rear Input Signal Missing ABS C1284 Oil Pressure Switch Failure HEC C1414 Incorrect Module Design Level RCM C1414 Incorrect Module Design Level RCM C1503 Right Front Isolation Diode ABS C1503 Left Front Isolation Diode ABS C1699 Rear Outer Left Sensor Circuit Short to Battery Parking Aid Module C1700 Rear Outer Left Sensor Circuit Failure Parking Aid Module C1701 Rear Outer Left Sensor Fault Parking Aid Module C1702 Rear Outer Right Sensor Circuit Short to Battery Parking Aid Module C1703 Rear Outer Right Sensor Circuit Failure Parking Aid Module C1704 Rear Outer Right Sensor Fault Parking Aid Module C1705 Rear Inner Left Sensor Circuit Short to Battery Parking Aid Module C1706 Rear Inner Left Sensor Circuit Failure Parking Aid Module C1707 Rear Inner Left Sensor Fault Parking Aid Module C1708 Rear Inner Right Sensor Circuit Short to Battery Parking Aid Module C1709 Rear Inner Right Sensor Circuit Failure Parking Aid Module C1710 Rear Inner Right Sensor Fault Parking Aid Module C1726 Air Suspension Pneumatic Failure Rear Air Suspension Control Module C1728 Transfer Case Unable to Transition Between 2H and 4H 4x4 Module C1729 Transfer Case Unable to Transition Between 4H and 4L 4x4 Module C1742 Rear Sounder Circuit Failure Parking Aid Module C1743 Rear Sounder Circuit Short to Battery Parking Aid Module C1748 Switch Input Circuit Short to Ground Parking Aid Module C1770 Air Suspension Vent Solenoid Circuit Failure Rear Air Suspension Control Module C1790 Air Suspension LR Air Spring Solenoid Output Circuit Failure Rear Air Suspension Control Module C1795 Air Suspension RR Air Spring Solenoid Output Circuit Failure Rear Air Suspension Control Module C1809 Air Suspension Vent Timeout Rear Air Suspension Control Module C1810 Air Suspension Height Sensor Out Of Range Rear Air Suspension Control Module C1811 Air Suspension Return to Trim Timeout Rear Air Suspension Control Module C1812 Air Suspension Height Sensor Failure Rear Air Suspension Control Module C1820 Air Suspension Air Compressor Request Exceeded Maximum Time Rear Air Suspension Control Module C1830 Air Suspension Compressor Relay Circuit Failure Rear Air Suspension Control Module C1920 LED No.1 Circuit Short to Ground Parking Aid Module C1972 Air Suspension Kneel Switch Circuit Failure Rear Air Suspension Control Module C1974 Air Reservoir Filling Error Rear Air Suspension Control Module C1993 Air Suspension Pressure Sensor Circuit Failure Rear Air Suspension Control Module C1995 Air Suspension Moisture Ejector Valve Circuit Failure Rear Air Suspension Control Module P0500 Vehicle Speed Sensor (VSS) Malfunction 4x4 Module P1139 Water in Fuel Warning Indicator Circuit Malfunction HEC P0500 Vehicle Speed Sensor (VSS) Malfunction OTC P1804 Transmission 4-Wheel Drive High Indicator Circuit Failure 4x4 Module P1806 Transmission 4-Wheel Drive High Indicator Short 4x4 Module P1808 Transmission 4-Wheel Drive Low Indicator Circuit Failure 4x4 Module P1810 Transmission 4-Wheel Drive Low Indicator Short 4x4 Module P1812 Transmission 4-Wheel Drive Mode Select Circuit Failure 4x4 Module P1815 Transmission 4-Wheel Drive Mode Select Short 4x4 Module P1819 Transmission Neutral Safety Switch Short Circuit to Ground 4x4 Module P1820 Transmission Transfer Case Clockwise Shift Relay 4x4 Module P1822 Transmission Transfer Case Clockwise Shift Relay Coil 4x4 Module P1828 Transmission Transfer Case Counterclockwise Shift 4x4 Module P1830 Transmission Transfer Case Counterclockwise Shift 4x4 Module P1832 Transmission Transfer Case Differential Lock-Up 4x4 Module P1834 Transmission Transfer Case Differential Lock-Up 4x4 Module P1865 Transmission Transfer Case Contact Plate Power 4x4 Module P1866 Transmission Transfer Case System Concern 4x4 Module P1867 Transmission Transfer Case Contact Plate General 4x4 Module P1876 Transmission Transfer Case 2-Wheel Drive Solenoid Circuit Failure 4x4 Module P1877 Transmission Transfer Case 2-Wheel Drive Solenoid Circuit Short 4x4 Module U1027 SCP (J1850) Invalid or Missing Data for Engine RPM HEC U1058 SCP (J1850) Invalid or Missing Data for Transmission Fluid Temp HEC U1059 SCP (J1850) Invalid or Missing Data for Transmission/Transaxle PRNDL HEC U1073 SCP (J1850) Invalid or Missing Data for Engine Coolant HEC U1147 Faulty SCP Link or Incorrect PCM Calibration PATS U1262 Missing SCP Message PATS U1262 SCP (J1850) Communication Bus Fault HEC U1950 UBP Communication Bus Fault VSM U1950 UBP Communication Bus Fault HEC U2015 Signal Link Fault (Non-SCP) OTC U2016 Signal Link Short to Ground (Non-SCP) OTC U2017 Driver Side Crash Sensor Communications Fault RCM U2018 Passenger Side Crash Sensor Communications Fault RCM U2306 UBP Invalid Data fom Node ID $60 (IC) VSM |
I have a 2001 f-150 supercrew with a 5.4 4 wheel drive I have a Rear dump outlet circuit malfuction. does anyone know what that might be? Any info would be great i called Ford and they never heard of it. I called about 5 local auto part stores and they never heard of it please help. The ABS light comes on every so often then can shut off.
To ryjmon
Please start a new thread or a new ? Two questions in one thread makes it hard to answer
Originally Posted by ryjmon
(Post 11523249)
I had the code scanned at a auto part store. The code is B1202. I thought it was a ABS speed sensor but i was wrong. Thanks
B1202 on a 2001 f150 is a fuel sender open circuit code.
how do i go by fixing that? would that cause my ABS light to come on?
No it would not. I would check the wiring back at the tank. Mice and squirrels love to chew the wiring back there and along the frame rail.
i will do some checkin thanks for the info
what would "Rear dump outlet circuit malfuction" mean?
(Post 11530040)
Does your fuel gauge work properly or not? If it does work properly, you have a bogus code. |
ya my fuel gauge works just fine
Did you get your ABS codes read at AutoZone? My ABS light is on sometimes and AutoZone hooked up their scanner and told me my codes were b1185 and b1226. But, the codes up on the second post describe my problems as c1185 and c1226. So your actual code may be a c1202. That dump valve sounds like something in the control module or pump to me.
