engine id for sure
Old Nov 15, 2005 | 07:41 PM
greythorn3's Avatar
greythorn3
engine id for sure
ook i got a straight 6 here is the block casting number C5AE-6015-F i heard it is a 300 straight 6 but want to confirm. was also wondering what bellhousing pattern this block is compatable with, i would really like to know if i can bolt a 360 inplace of this engine to the tranny that is hooked up to this straight 6, any help would be appreciated
Ray
Old Nov 15, 2005 | 07:49 PM
ford390gashog's Avatar
ford390gashog
the 240/ 300 use the small block bellhousing 302 351w the 360 fe shares no bellhousing pattern with anything so you need a new tranny.
Old Nov 15, 2005 | 07:58 PM
greythorn3's Avatar
greythorn3
tranny?
couldnt i just get a new bellhousing and reuse the existing tranny?
ray
Old Nov 16, 2005 | 09:38 AM
Mike G's Avatar
Mike G
Ray - You should be able to reuse the tranny with whatever motor you decide to go with. One thing though.... If you are mounting this up in your 65 4x4, I believe you will need to find a front timing cover and bellhousing that will allow you to mount the motor correctly, I don't think they use the standard side engine and tranny crossmember mounts. If memory serves right (now that's a stretch) you will need a front timing cover that will have the motor mount attached, as well as a bellhousing with mounting ears. Unless of course you have a swap kit. Let me know if I'm wrong on my analysis (for future reference).
--Mike
Old Nov 16, 2005 | 03:19 PM
greythorn3's Avatar
greythorn3
no
im transplanting the cab onto the 76 frame i got, it just has a c6 on back the 360 and i want to use the orig 4 speed and xfer case outa the 65
ray
Old Nov 17, 2005 | 10:10 AM
Mike G's Avatar
Mike G
You will need to pick up a FE 4-speed bellhousing (and related 360 clutch parts), the tranny should still fit up to it and you can build from there.
--Mike
Reaper76
Dec 13, 2013 03:58 PM
johncardi
Jul 13, 2009 03:29 AM
gdw3138
Apr 19, 2005 10:01 AM
straight 6's
Jun 16, 2004 09:43 PM
924x2150
Nov 24, 2003 02:18 AM
