Engine won't idle
Old Nov 15, 2005 | 08:14 AM
MICBAR's Avatar
MICBAR
Unhappy Engine won't idle
My F150 recently started running rough, and now won't idle. The gas mileage is terrible! Someone said it was idle sensor, and to unhook battery to reset computer. That didn't help? The engine light stays on too. Will I have to have
someone hook computer up to it? Thanks.
Old Nov 15, 2005 | 09:51 AM
Bronco308's Avatar
Bronco308
What model year and engine cid? My sons 92 302 was doing the same thing and we had to replace a sensor on the drivers side of the throttle body; sorry, I can't remember what the sensor was called now. You can disconnec the electrical plug on the sensor to see if you get an RPM increase. Autozone was also able to test it for us.
Old Nov 15, 2005 | 09:55 AM
subford's Avatar
subford
Take it to autozone and have them read the codes, do not buy anything, come back here and post the codes and we will try to help you.
Old Nov 15, 2005 | 10:06 AM
MICBAR's Avatar
MICBAR
It is a 91 302. So if I disconnect the plug on driver side and RPM increases...it is bad? Thanks Bronco
Old Nov 15, 2005 | 10:22 AM
subford's Avatar
subford
That item on the drivers side of the throttle body is not a sensor, it's the Idle Air Control (IAC) Solenoid. There is a sensor on the bottom of the throttle body called the Throttle Position (TP) Sensor. It can cause this problem also.
Old Nov 15, 2005 | 10:25 AM
MICBAR's Avatar
MICBAR
Thanks for the help subford!!
Old Nov 15, 2005 | 10:29 AM
pfogle's Avatar
pfogle
MICBAR, if you unplug the connector and the idle drops then it's working. It's probably just stuck and dirty.
Old Nov 15, 2005 | 10:59 AM
MICBAR's Avatar
MICBAR
So the Throttle Position (TP) Sensor is located at the bottom? Any idea what color the wires at the connector are?
Old Nov 15, 2005 | 11:38 AM
subford's Avatar
subford
The connector I think they are talking about is the one on the IAC not the TPS.
Here is some photos of both.
Old Nov 15, 2005 | 11:41 AM
MICBAR's Avatar
MICBAR
You are a good man subford!! Thanks
Old Nov 15, 2005 | 11:55 AM
Bronco308's Avatar
Bronco308
Smile
Thanks for clearing up my phraseology! I was told that if you ever have to remove/replace the TPS, to make a mark on it and the throttle body to help with calibration.
Old Nov 15, 2005 | 11:59 AM
92 f150 custom's Avatar
92 f150 custom
Hey guys. I had a cougar with the 3.8 v6 that had the same type problem and it ended up being a large vaccum line on the underside of the upper intake manifold had come loose. Just something to think about. Tim
Old Nov 15, 2005 | 12:49 PM
MICBAR's Avatar
MICBAR
I have photo...how do I get it on here?
Old Nov 15, 2005 | 01:35 PM
MICBAR's Avatar
MICBAR
Angry Codes
I went to autozone today, they couldn't read the codes at this time.
Old Nov 15, 2005 | 04:20 PM
subford's Avatar
subford
1. Go up near the top and piont to Galleries, then click on Manage/Create.
2. Click on Create Album
3. Give the information it wants.
4. Click on Create Album at the bottom
5. When it comes up click on edit to the left of the name you gave it.
6. Go down and click on Browse..
7. Choose a file in your computer.
8. Click Open.
9. Click Upload.
10. When its done go down and click on [Forum Codes]
11. Highlight the information in the box.
12. Do a "Ctrl" "C"
13. In your post where you want it just do a "Ctrl" "V".
and that’s it.
