Engine won't idle
Old Nov 15, 2005 | 04:24 PM
subford's Avatar
subford
Originally Posted by MICBAR
I went to autozone today, they couldn't read the codes at this time.
How come they could not read them at that time?
Old Nov 16, 2005 | 07:52 AM
MICBAR's Avatar
MICBAR
They said it wasn't working.
Old Nov 16, 2005 | 11:36 AM
MICBAR's Avatar
MICBAR
Engine Won't Idle
Subford....here's a photo. Is this the IAC or the TPS? Thanks again.
Old Nov 16, 2005 | 11:50 AM
subford's Avatar
subford
It's an IAC.
Start the engine and while it is Idling pull the plug off, if the RPM's drop and then it dies, it is working. If nothing changes it is stuck or bad. If it is stuck, take it off and spray carb cleaner in and around the two holes. If you can put 12V on the two pins while it is off and watch for any movement inside, You will also hear a click.
When you take it off you remove the bolts that go into the throttle housing and not the screws that you can see in your photo.
Old Nov 16, 2005 | 11:58 AM
MICBAR's Avatar
MICBAR
Yes I did remove the plug and the RPM's dropped and then it died. So this means it's working? I need to check the TPS?
Old Nov 16, 2005 | 12:38 PM
subford's Avatar
subford
Yes it is working OK (the IAC).
The TPS is more than likely OK but to check it, engine off, unplug it and it will have three terminals labeled A, B, & C.
You would need to +5VDC on C and the neg from the supply on A.
The center pin (B) is the output and will read (or needs to be) 1 VDC with the Throttle closed and about 4VDC open. The 1 VDC is the adjustment if it has one and needs be adjusted to one volt.
This is normally done with a breakout box hooked to the EEC and the one volt is at pin #47 (+) and #46 (-).
Old Nov 16, 2005 | 12:55 PM
subford's Avatar
subford
My F150 recently started running rough, and now won't idle. The gas mileage is terrible! Someone said it was idle sensor, and to unhook battery to reset computer. That didn't help? The engine light stays on too. Will I have to have
someone hook computer up to it? Thanks.
OK, with all of that out of the way let’s rethink this. We need to read the codes and you say autozone will not do it for some reason. We need to ground a pin on the test (DLC) connector and watch the check engine light. Count the flashes and see what they say.
Here is how you do it.
http://fordfuelinjection.com/?p=13
Good luck
Old Nov 16, 2005 | 01:22 PM
MICBAR's Avatar
MICBAR
Thanks subford....I will try this today after work. I really appreciate you taking the time to help me!!
Old Nov 16, 2005 | 02:05 PM
MICBAR's Avatar
MICBAR
Ok...to check the TPS I will need to see if terminal C has +5VDC on it and the neg from the supply on A.The center pin (B) is the output and will read (or needs to be) 1 VDC with the Throttle closed and about 4VDC open? Correct? The 1 VDC is the adjustment if it has one and needs be adjusted to one volt.
Is this right?
Old Nov 16, 2005 | 06:08 PM
subford's Avatar
subford
Is this right?
Yes, but more closer to 5VDC on the open Throttle.
I do not know how you are going to do this without a breakout box or a portable 5VDC supply unless you stick a straight pin in the center B wire (GRY/WHT) and the other end of your meter to a good ground.
More than likely the TPS is non-adjustable and you will only be looking for the 1 VDC and 4.8 VDC readings with the key on engine off. If you get them it is OK.
Old Nov 16, 2005 | 06:57 PM
cody123's Avatar
cody123
I am having the same problem with my 90' 351ci. the same symptoms as MICBAR's only the exhaust is really rich. I checked both the IAC and TPS the way subford explained and i found nothing is there anything else that could cause this Im pretty lost.
Old Nov 16, 2005 | 09:34 PM
subford's Avatar
subford
cody123
I do not think and never thought that the IAC or TPS was his problem but I was just trying to prove to him that they were not his problem without him spending a lot of money.
More that likely he has a bad ECT, ACT, HEGO or MAP sensor.
I would like to see if he has any codes that would point to any of these sensors.
Of course the Thermostat could be stuck open too.
This would apply to your truck also.
Old Nov 17, 2005 | 12:58 AM
  #28
cody123's Avatar
cody123
Does autozone rent out code readers because I dont wanna chance driving the truck with 2001 tags on it.
Old Nov 17, 2005 | 07:59 AM
  #29
subford's Avatar
subford
You do not need one to get the codes, just go to this URL and it will tell you how.
And here is quick diagram borrowed from Dave Franklin's gallery.
Old Nov 18, 2005 | 10:30 AM
  #30
MICBAR's Avatar
MICBAR
OK last night I did the code test with the Engine Light. It ended up 63,63,11, & 11. I did this several times to make sure. Where do I find out what this means? Thanks.
