heater problem
Old Nov 15, 2005 | 06:08 AM
oldtrapper's Avatar
oldtrapper
heater problem
I a .m trying to get some heat for my 66 and have rhe usual assorrment of frozen cables. I have ordered the valve for under she hood. Is the blower protected with a fuse? 10 amp
Trapper
Old Nov 15, 2005 | 06:54 AM
44dwarf's Avatar
44dwarf
Not sure on the fuse but on the top of the heater box you should have two orange wires they go to an open air resitor for the speed control if thats bad the blower goes dead.
44
Old Nov 15, 2005 | 03:02 PM
59INA40's Avatar
59INA40
Oldtrapper, while you have the heater valve out of the truck, it would be good if you were to remove the cable from the dash and take it for a visit to your parts wash. You will be amazed at how much easier it works when 40+ years of crap are rinsed out of the cable housing. When you are convinced that you can't get any more crud out of it, apply a generous amount of penetrating oil and put it back together. I've had mine out twice since the late eighties and it works like new. If you don't have a parts wash with solvent, WD40 will work well and lubricate it at the same time. Keep running it back and forth throught the housing until your rags aren't dirty. Steve
trepid94
Sep 18, 2016 11:48 AM
53 fatty
Florida Chapter
Mar 19, 2014 08:48 PM
hotbbb
Apr 5, 2004 02:15 PM
jakegypsum
May 10, 2002 09:12 AM
daywalker
Feb 19, 2002 09:55 PM
