429 performance?
Old Apr 3, 2004 | 10:41 AM
hotbbb's Avatar
hotbbb
429 performance?
i am having a 429 put in my heavy 72 torino. I wanted to have at least 420 hp what kind of parts would i have to have .thx
Old Apr 3, 2004 | 05:09 PM
Brad Johnson's Avatar
Brad Johnson
Where do you want the torque to peak - just off idle, midrange, or upper RPM?
Brad
Old Apr 4, 2004 | 02:39 PM
hotbbb's Avatar
hotbbb
midrange, a good street racer on the weekends but a daily driver
Old Apr 5, 2004 | 02:15 PM
Brad Johnson
I ran a couple of sims with the following baselines
10.0:1 CR
Dual plane intake
750 cfm carb
Headers w/small tube primaries
Moderate head work (port matching and chamber polishing)
Here are the numbers from the cams indicated...
Comp Cams 280H
Torque - 470 @ 4000
Horsepower - 413 @ 5000
Lunati 00096
Torque - 478 @ 3500
Horsepower - 418 @ 5000
Crane Powermax H-288-2
Torque - 468 @ 4000
Horsepower - 414 @ 5000
Edelbrock Performer RPM Hydraulic 7167
Torque - 447 @4500
Horsepower - 419 @ 5500
You could increase those numbers somewhat with a little more attention to head work, but I don't know if the added expense would just be justified. Any of the above combos would certainly be a very nice street mill.
Unless you already have the 429 purchased (and maybe even if you do) you would do your self a favor to go to a 460 block as the extra cubes would give you a nice boost in HP and torque. Since all the combos above made almost 1hp per cu inch, and over 1 lb-ft torque per cubic inch, the added 30 cubes would make a noticeable difference with zero penalty in weight and cost )if you can find a gimme block in good shape). You would be at - or over - 500 lb-ft torque and 450 hp with just the change in displacement.
Brad
