Full floating axle question!
Old Mar 13, 2002 | 01:59 PM
supercab78's Avatar
supercab78
On F-250 with a full floating axle what is the proper tension to put on the bearing? Do you leave just a little play simular to front wheel bearings? Thanks Jeff
Old Mar 13, 2002 | 04:11 PM
Ford79's Avatar
Ford79
I just looked in my repair manual and it says: While rotating the hub/drum assembly tighten the adjusting nut to 50-80ft-lbs. Then back the nut off 3/8 of a turn, install the lock washer(smooth side out) and finally the lock nut torqued to 90-110 ft-lbs.
Old Mar 15, 2002 | 12:08 PM
supercab78's Avatar
supercab78
thanks ;ford79
Old Mar 15, 2002 | 04:08 PM
jayjay's Avatar
jayjay
obscurity
Jun 30, 2013 11:35 AM
volks
May 24, 2010 11:09 PM
sc4x4
Oct 24, 2005 07:53 PM
mpalamaras
May 27, 2003 05:38 PM
Nathan
Mar 7, 2002 09:02 AM
