full float axle re-assembly question
Old Jun 29, 2013 | 09:16 PM
obscurity's Avatar
obscurity
I am putting my full float axle back together and I have a question. When assembling a standard axle you have to repack the bearings but what do you do with an axle that uses oil instead of grease. Do I just dip the bearing in oil before assembly and hope for the best or is the a better way to protect the bearings until oil makes it down from the diff?
Old Jun 29, 2013 | 09:24 PM
JWC 3's Avatar
JWC 3
Coat the bearings with assembly lube and fill the hub well with gear oil . And , fill the rear end and jack up one side of the rear to tilt the axel to allow oil to run to wheel hub . Recheck oil and jack other side .
Old Jun 30, 2013 | 11:18 AM
obscurity's Avatar
obscurity
Do you have to use a gasket for the axle flanges or can you use RTV?
Old Jun 30, 2013 | 11:35 AM
JWC 3's Avatar
JWC 3
I use RTV ( permatex ultra black ) on most . I have seen good results with no leaks .
charleswood6969
Mar 26, 2015 11:39 PM
Iallwork
Oct 10, 2011 07:58 AM
john fin
Jul 27, 2009 01:38 PM
AnOldDog
Oct 15, 2005 11:44 PM
1990350
Feb 23, 2003 12:31 PM
