HELP!! Will not shift into overdrive
Old Nov 14, 2005 | 06:55 PM
empiretc's Avatar
empiretc
Question HELP!! Will not shift into overdrive
As an update/continuation to this thread:
https://www.ford-trucks.com/forums/s...d.php?t=429574
It wasnt anything in the valve body. Truck shifts into 2nd great but will not go past that. I noticed right away when it shifts into 2nd the RPMs are still higher than before- around 1800.
The overdrive light was blinking so I know I'll have to get the code read.
Just want some more input before I have to take it to the shop....
Old Nov 14, 2005 | 07:16 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
did you leave an "f" out of the title?
Old Nov 14, 2005 | 07:22 PM
empiretc's Avatar
empiretc
HAHAHA, LOL
Yeah, I just noticed. It has been a hell of a day and I am still bummed out. Truck is on my mind...
Old Nov 14, 2005 | 11:47 PM
Kwikkordead's Avatar
Kwikkordead
Did you catch this thread?
https://www.ford-trucks.com/forums/s...d.php?t=428722
Old Nov 15, 2005 | 04:11 PM
empiretc's Avatar
empiretc
I took it to the shop. Oh well, I know it is the stock tranny and it did feel like it was getting weak. I guess the tighter springs were enough to break it. I am one sad man...
Old Nov 15, 2005 | 04:46 PM
PowerstrokeJunkie
oh, it actually broke? what happened to it?
Old Nov 15, 2005 | 06:51 PM
empiretc's Avatar
empiretc
Guys hooked the scanner and it did not dump a code. They went through testing the VSS and Solenoids, and everything checked out. They are going to check into it some more and let me know. I'll keep you guys informed.
Old Nov 16, 2005 | 08:45 PM
empiretc's Avatar
empiretc
I stopped by to check on my baby today, and they showed my two broken clutch plates. They also told me there were some stuck/broken vlaves. This repair is gonna cost me around 1k. Couldnt have some at a worst time...
Old Nov 17, 2005 | 06:47 PM
empiretc's Avatar
empiretc
$837.59 total cost of rebuild and new tc.
They put the sonnax kit in and with the other 2 springs they put in. Man it shifts better then my father in laws brand new truck. And that vibration that I thought was the ujoints again is GONE. It runs GREAT. thanks to all for putting up with me while I got through this.
Old Nov 17, 2005 | 06:59 PM
MRBASS's Avatar
MRBASS
Broken clutch plates? Stuck and broken valves? What was the cause of all that?
Old Nov 17, 2005 | 07:11 PM
4X4 IN REFUGIO's Avatar
4X4 IN REFUGIO
Yes Tell Us ... What Causes Those Things To Happen.
Don't Want It To Happen To Me.
Have You Been Rough On The Truck?
Old Nov 17, 2005 | 08:24 PM
empiretc's Avatar
empiretc
nope. I have only had it for 6 months and i drive like a grandpa. Always keep it under 2k rpm even when accelerating. But since I first got it the tranny felt a little funny and I was finally convinced to put in the sonnax kit to get rid of the problem. It did for 2 days, and then all hell broke loose. I think the tranny was on its way out and the tighter springs were just enough to finish the job.
dustin52
Sep 24, 2010 10:10 AM
rankins66
Aug 17, 2010 03:45 PM
powercrazy3
Apr 9, 2009 09:49 PM
woodly1069
Jan 30, 2008 08:04 AM
handyman43358
Jan 12, 2005 08:48 PM
