Temp gauge question
Old Nov 13, 2005 | 11:46 PM
probedude's Avatar
probedude
Temp gauge question
Driving my newly purchased used Ranger home from work one day (93' 3.0L 2WD 5spd), I noticed the temp gauge slightly above half, then would drop to 1/3rd - hang there for a while, then climb back up and repeat the sequence. Not rhythmically so I thought it was a bad t-stat.
Trying to drain the radiator and not being able to, I discovered 3/4 of radiator was clogged from loose scale.
I flushed the heck out of the original radiator and engine, put in a new t-stat and also put in Prestone Super Flush and drove the truck for 3'ish days (~ 6 hours total).
Tonight I drained the coolant, flushed the cooling system 3x with purified water, then installed a new radiator and filled with ~ 60% antifreeze/40% purified water, burped the cooling system and shut it down.
Later I went for a drive on the freeway - and saw the temp gauge kind of doing the same thing! It wouldn't go past the halfway mark, but it would definitely swing between the 1/4 to 1/3rd. Again not rhythmically so I don't think it is the gauge regulator.
Is this typical? The radiator and T-stat are new, fan clutch seems fine. No scale came out from the 3x flushing I did tonight (I think I got them all from the original flush 2 weeks ago). No AC condensor in the way of airflow to the radiator.
Where does you temp gauge sit when fully warmed up? Does it 'move' around?
TIA,
Dave
Old Nov 14, 2005 | 10:34 AM
Rockledge's Avatar
Rockledge
Maybe the temperature sending unit is flaking out. It's the single wire sensor up near where the T-stat housing is. Not terribly expensive and rather straightforward to replace.
Old Nov 14, 2005 | 09:53 PM
handyman43358's Avatar
handyman43358
My stock ranger gauge fluctuates quite a bit. Not as much as yours though. It will stay a tick below N and then sometimes move up to R. I put an aftermarket gauge in and it stays at 178-182 all the time.
Old Nov 14, 2005 | 10:20 PM
RangerPilot's Avatar
RangerPilot
Mine never moves. Well obviously as it warms up, get's to about halfway between 1/4 and 1/3, then just sits there.
tjc transport
General Automotive Discussion
Nov 9, 2014 07:06 AM
tjc transport
Nov 5, 2014 02:25 PM
whiteboyslo
16
Mar 9, 2014 12:42 AM
69cj
Oct 27, 2009 07:11 PM
KR1
13
Jun 25, 2009 01:59 PM
