My MOTOR"S book from back then says cam gear mark at 6 and crank gear mark at 12.
"to install the chain, algin the slotted camshaft spacer with the dowel hole in the cam. Position the sprockets and chain on camshaft and crankshaft. Be sure the timming marks on sprokets are positioned as above.Install fuel pump eccentric and cam sprocket cap screw."
