Sponsored by: Auxito
Climate Control Wiring Question
Old Nov 12, 2005 | 06:22 PM
ProfessorOhki's Avatar
ProfessorOhki
Do any of you know (or know where I might find) a list of the pinouts or a schematic for the AC / Temperature / Fan controls? Vehical in question is a 1998 F-150. I tried looking around the old posts a bit, but couldn't find exactly what I was looking for.
The more detailed you can be the better. Thanks
Old Nov 12, 2005 | 11:22 PM
BillyBob69's Avatar
BillyBob69
It may cost you about $14 but a Chilton's manual csn be a life saver.
Old Nov 13, 2005 | 12:05 AM
ProfessorOhki
I actually have one sitting on my lap, but it shows where and into what they plug into, it doesn't describe the function of the wire bundles or the wires. Or says something like "fan control wires to blower." Now I assume that the fan control is a 5-way rotary switch, and the A/C probably is too, but what about the temperature, is it some sort of potentiometer? If it is, what its resistance range?
Old Nov 14, 2005 | 08:20 AM
BillyBob69's Avatar
BillyBob69
I believe the temperature is a pot directly on the control. Sorry it has been awhile since I dove into the climate controls.
Anyone else chime in?
Old Nov 14, 2005 | 08:43 AM
ProfessorOhki
I suppose I should include why I want the information. I'm considering making an electronic climate control system of my own, or at least interface the existing one to a digital system. So, I'm trying to figure out what sort of method I'd have to apply to convert those three ***** to something a digital device could control.
Old Nov 14, 2005 | 08:47 AM
BillyBob69's Avatar
BillyBob69
Have you thought about maybe trying to scavenge an electronic system from another vehicle, (after checking the wiring for it), and retro fitting it to yours? You are talking about a Ford. Maybe there is something in a Mercury or even another Ford with fancier options that has what you are looking for. Could make it easier.
Old Nov 14, 2005 | 09:47 AM
MrBSS's Avatar
MrBSS
Yeah, it seems like that would be easier. I've been wanting to change mine to EATC since I bought it, but still haven't got around to it. Since the later Lariots had EATC, not to mention many of the similar Expys and Navigators, it should be relatively easy.
I'd at least like to set it up so that it would sense the coolant temperature and not blow air when on the "floor" position until it heated up. Before they had Automatic Temp Control, many vehicles had that at least.
Old Nov 14, 2005 | 02:29 PM
ProfessorOhki
Well, the idea crossed my mind briefly, but I'm a computer engineering student and something I'd eventually like to accomplish is having an in-car computer with audio, climate control, video, real-time specs, and maybe navigation tied togeather into one interface. So, it will require some custom hardware/software. I'm considering this project more for the fun and the challenge of doing it than the actual convience. (95% of the time I just have the thing set to no fan and vent ) If I'm lucky I might even pass it off as a senior project
mybitta1
May 21, 2014 01:00 PM
Nitesaber
Jul 7, 2011 01:55 PM
Sabreliner80
All Things Towing
Sep 5, 2010 06:56 PM
guthrie&co
Jan 21, 2010 08:25 AM
ridgerider3
Jul 10, 2009 04:36 PM
