1978 - 1996 Big Bronco
stalls when engine is cold
Old Nov 12, 2005 | 03:13 PM
sealka's Avatar
sealka
Cool stalls when engine is cold
I have a 93 bronco 5.0, Have promblems with keeping it idleing when cold. The chock will come on for about 30 seconds, and It will shut off if I do not give it a little gas. Once the motor is warmed up it will idle fine, at about 800 rpms. Could it be the throttle position sensor or the idle air control.
Old Nov 12, 2005 | 08:59 PM
Greezy's Avatar
Greezy
I have this same issue with my 87'. Let me know what you find. EGR perhaps?
Old Nov 12, 2005 | 10:49 PM
greystreak92's Avatar
greystreak92
Start by cleaning the IAC with a good throttle body cleaner. IF that does nothing for you pull the codes. It sounds like the IAC has failed but you can pull the codes to be certain. Once you have the KOEO and KOER test results (Codes) you will be able to pinpoint the problem much better than if you start by guessing. ANY situation that has caused the engine to shut down will trigger an error code of some kind. If you need info on how to pull them check your Haynes manual or www.fordfuelinjection.com
If you need help interpreting or discerning just what the "fix" for each code should be, let us know. We can certainly help there.
Old Nov 13, 2005 | 05:14 PM
54Guy's Avatar
54Guy
Have a similar problem just starting with my '89 with the 5.8 engine.
Old Nov 15, 2005 | 03:41 PM
sealka's Avatar
sealka
I Cleaned the throttlebody and the idle air control with throttlebody cleaner, it seems to be idleing fine now. It idles at a 1000 rpms, with no hesitation.
Old Nov 15, 2005 | 03:45 PM
sealka's Avatar
sealka
I cleaned the throttlebody and idle air control with "CRC" brand throttle body cleaner. That seems to work, it idles fine at 1000 rpm and does not shut off.
Old Nov 15, 2005 | 04:02 PM
Kemicalburns's Avatar
Kemicalburns
the idle does drop down after a little while right. because 1000 rpms is high for normal operation
Old Nov 15, 2005 | 07:53 PM
greystreak92
Kem is right, normal speed is 700-900 rpm @ curb idle (engine running, auto transmission in a non-moving gear/ manual transmission out of gear). If it does not drop down after a few minutes to within this range, you may still have an IAC issue.
daddylee100
Dec 29, 2015 06:03 PM
aleh61
Aerostar
Apr 8, 2009 04:26 PM
96gizmo
Jan 31, 2005 09:30 AM
Bristrew
Jan 12, 2005 08:18 PM
gregarious1
1997 - 2003 F150
Jan 9, 2005 02:44 PM
