ported head
Old Nov 12, 2005 | 10:32 AM
4.9inline6's Avatar
4.9inline6
Question ported head
as many already know, i am doing an engine swap. the reberbished one i have is completely stock except for what the company did when the referbished it. for instance, the block is now .040-.060 over, the crankshaft is .010-.030 under, and if it the onther engine parts were not remanufactured, they were replaced with new parts. with the block being bored and the crankshaft being ground, is that going to give me anything at all? besides this, i am putting exhaust on it and intake and little things here and there. i also have a mechanic friend that can port heads. with everything stock, how much is the head porting going to give me? do i need to do anything else to go along with the ported head? should i get the head ported now, before i break in the engine, or should i drive the truck for a while (isn't it 1000 miles to break in a new engine?) then have him port the head? also, if he charges me, how much would you expect to pay for getting heads ported? i want to get some more power for pulling but don't necessarily need ole blue to hit 700 on the horsepower scale (though that would be pretty cool). any ideas or input would be appreciated. thanks.
Chris
Old Nov 12, 2005 | 10:50 AM
CMOS's Avatar
CMOS
I'd like to hear some of the answrs to your questions. Firstly - is this an EFI or carbed engine?
As far as the head porting, I see no reason why you wouldn't want to port the head immediately as opposed to later after a break-in.
CMOS
Old Nov 12, 2005 | 11:30 AM
Motorhead351's Avatar
Motorhead351
Open up the bowl area and leave the ports alone, this will net you a little more hp with the stock cam.
By your mention of intake, sounds like this is a carbed engine, it would be a good time to put a little more cam in it to compliment the intake/ exhaust and head work. Comp cams has a couple cost effective camshafts, paw performance offers a cheaper generic grind but it works well for a mild application.
I would expect to pay $200-500 depending on whos doing it.
Old Nov 12, 2005 | 12:54 PM
4.9inline6's Avatar
4.9inline6
actually it is fuel injected. it is a 93 f250 if interested. motorhead when you say open up the bowl area, what do you mean? thanks
chris
Old Nov 12, 2005 | 12:59 PM
Tnehring14's Avatar
Tnehring14
i think he meant as far as it being carburated.
Old Nov 12, 2005 | 03:02 PM
Motorhead351
If you remove the valves on a head, you will see alot of material around the valve/valve guide out to the port wall, this is the "bowl" area. By taking the time to remove material and shape this area, you increase the heads ability to flow which equals more power.
You threw me completely off then when you said your adding intake, my question, what intake, as far as I know, stock is it?
It would still be a good time to upgrade the camshaft and do the port work, be a whole lot easier now, than later when its installed.
Good luck
Old Nov 13, 2005 | 08:29 AM
4.9inline6's Avatar
4.9inline6
Thanks. i get what you are saying now. at the moment i have a stock intake but plan to upgrade it to cold air intake or whatever.
Old Jan 18, 2006 | 09:17 PM
4.9inline6's Avatar
4.9inline6
i am taking a class where i can port my heads for free (i just found this out this morning!! ) ...i know motorhead said to open up the bowl area instead...can i do both...i don't know much about this because i have never done this before....i can get all head work done for free and the guy said that he can do some other stuff to the ....valves....maybe.....
what is the best thing/things to do to get the most horsepower...remember, this is a mainly stock engine. thanks
chris
Old Jan 18, 2006 | 09:19 PM
4.9inline6's Avatar
4.9inline6
by headS i mean head...4.9 i6, fuel injected.
"what is the best thing/things to do to get the most horsepower?"
what i mean is what are the best things to do while i have the head out and am getting grinding work done for free...
thanks again
chris
Old Jan 19, 2006 | 10:17 PM
4.9inline6's Avatar
4.9inline6
no thoughts? if anyone replies to those questions, another question outta curiousity is how does this affect gas mileage?
chris
GloveGuy
May 7, 2016 06:43 PM
Rusty_S
General Automotive Discussion
May 5, 2010 05:02 PM
TKKTommyboy
Jan 19, 2007 11:25 AM
youngguy
Mar 15, 2004 08:07 PM
