Injection Pump Info
Old Nov 12, 2005 | 09:19 AM
ziffle's Avatar
ziffle
Injection Pump Info
THIS IS MY FIRST DIESEL. AND I HAVE A QUESTION? on my injection pump on the drivers side ther is an electric connection and i dont know what is for. there is allso alever that pushes on alever it is un hooked what is it for? and what is it?
Old Nov 12, 2005 | 10:45 AM
PLC7.3's Avatar
PLC7.3
We want to help BUT we need truck year etc info. Put up a signature with info in it, go to Quick links above and edit a signature.....
Old Nov 12, 2005 | 01:45 PM
bilder12's Avatar
bilder12
IF its 89 or newer, the connection is probably the trans control (E40D trans). The lever explanation, i dont understand. If its older than 88, and the trans is a 3 speed auto, the lever stuff on the pass side of the pump is for kickdown linkage. More infor about the truck is helpful.
Old Nov 12, 2005 | 03:48 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Welcome to Ford Truck Enthusiasts ziffle.
Glad you've chosen the best site for Fords.
Old Nov 12, 2005 | 06:49 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Drivers side electrical connections, front one is the fuel shut off solenoid, back one is the timing advance solenoid.
Levers on the drivers side are throttle front and timing advance rear straight up and down.
Old Nov 13, 2005 | 07:33 AM
ziffle's Avatar
ziffle
thanks thats what i thought. but wasnt sure all i know is that its unhooked looks like the set screw has been taken out. and it just turns freely on the throttle shaft. by the way im from salem wv. by any chancedave you go to doddridge?
Old Nov 13, 2005 | 12:47 PM
Dave Sponaugle
I have not been to Doddridge county very many times at all.
Since you are so close give me a call.
669-1253
I will help you get it straight.
What year is your truck?
Deereguy90
Aug 16, 2011 10:05 PM
ghunt
General Diesel Discussion
Jan 4, 2008 02:56 PM
hotrob
Nov 29, 2006 07:36 AM
poston
Sep 19, 2006 09:49 PM
Heatnbeat
Jan 5, 2006 09:13 PM
