broken leaf springs
Old Mar 25, 2002 | 10:28 AM
ford_nut's Avatar
ford_nut
broken leaf springs
i was doing the brakes on my 74 f250 the other day and i noticed that 3 center leaves in the right rear spring pack were broken. i cant imagine how 3 leaf springs in the center of the pack can just break in half. how does this happen? what causes it? is this a dangerous situation?? would this cause the rear of the truck to sag substantially? thanks!
Old Mar 25, 2002 | 10:32 AM
sturzinator's Avatar
sturzinator
broken leaf springs
Old Mar 25, 2002 | 03:57 PM
dfisher1's Avatar
dfisher1
broken leaf springs
Nut,
This is more common than you might think. Over loading a truck and getting off road can do a number on leaf springs but a few things have to happen first.
1. The leaf springs must be rusty. A binding of the springs is a must. I.E. rust.
2. There must be a load on the truck. Then there must be a rapid input to the suspension. The heavy load causes a large displacement of the springs and the rust causes them to bind and fracture.
There is a solution:
1. Remove your leave springs. Have springs bead blasted and paint your leave springs. It's a pain and thats why it wasn't done from the factory.
2. Remove springs and place teflon shims (0.010") between them.
3. The worst one. Pull'em apart and grease them up.
My Way is the Highway
KingFisher
Old Mar 25, 2002 | 04:10 PM
77460ford's Avatar
77460ford
Post broken leaf springs
Having "been there done that" several times with my leaf springs, Kingfisher nailed it right on the head. It's not the most fun job,but if longevity and reduced further maintenance are your goals then its the way to go. Besides, its a good time to do those spring bushings to.
NW 150
Sep 6, 2014 08:44 PM
Bootlegger's Deluxe
May 19, 2011 08:24 PM
djeclipse
1983 - 2012 Ranger & B-Series
Feb 21, 2007 03:49 PM
fellro86
17
Sep 13, 2005 11:58 PM
Idiomaticman
Offroad & 4x4
Jun 7, 2004 12:40 AM
